skeates |
Member ![]() ![]() Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California ![]() |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,119 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
One thing I have heard that is important here, if it's true: The expanding foam will continue to expand, slowly, for weeks.
--DD |
skeates |
One thing I have heard that is important here, if it's true: The expanding foam will continue to expand, slowly, for weeks. --DD Thanks for the heads-up Dave - I'll have to keep an eye on things. The can indicates that it takes 8 hours to cure so I've been spraying and then letting it sit over night before doing any shaping. I haven't noticed any movement with the stuff I've already shaped, but maybe it just hasn't been long enough yet. |
Lo-Fi Version | Time is now: 13th March 2025 - 04:18 PM |
