Turning a modified 914-6 back close to original, Are the upgrades worth anything? |
dw914six |
Sep 3 2014, 08:07 PM
Member Group: Members Posts: 131 Joined: 18-January 14 From: Houston Member No.: 16,902 Region Association: Southwest Region |
I own 2 914-6 (authentic) cars. 1 is slightly modified with some upgrades to make it more usable and perform a bit better.
My other car (Big Red) is a highly modified 1970 914-6 (in GT form). (IMG:style_emoticons/default/evilgrin.gif) I have always wanted to pull off the upgrades and put the original engine back in, etc. This car currently is running a 911 3.6 twin plug from a 964. Below is a list of some upgrades. • Porsche 964 engine • 50mm PMO Webers • Electromotive twin-plug crank fire ignition • Aase RSR valve springs, titanium retainers • Web Euro-spec camshafts • Patrick Motorsports Jet-hot coated racing headers and sport muffler • 901 side-shift gear box with 904 main shaft and short gears • MOMO competizione shift knob • Automation billet aluminum intermediate plate • 225mm Patrick Motorsports lightweight clutch • Patrick Motorsport RSR aluminum flywheel • Quaiffe LSD and billet side-plates • Automotion solid transmission mounts • B&B 930 front mounted engine oil cooler with thermostat • 911SC front suspension with aluminum cross brace • Porsche (Big Red) Twin Turbo front and rear brakes • Pagid racing brake pads • 23mm Gun-drilled front torsion bars • 930 tie rods • Charley front sway bar • Porsche Factory rear sway bar • Porsche RSR threaded front Bilstein struts and sport valve shocks • Eibach rear coil over springs • Automotion adjustable monoball upper strut mounts • Poly-graphite suspension bushings • 19mm Master cylinder • Kinesis 17 X 8 and 17 X 9 ½ three piece racing wheels (polished) • Fresh Goodyear Eagle F1 tires • 914-6GT chassis stiffening kit • 914-6GT boxed rear suspension • Porsche Factory GT precision butt-welded steel flares • Composite front and rear deck lids • Factory GT composite racing seats • MOMO prototipo steering wheel • SPA fire system • Porsche Factory fuel tank with Patrick Motorsports fuel – safe cell • Martin Baker vintage exterior fuel cap • New factory interior • Bell seat belts • Rennline Pedal box • Adjustable brake bias with hydraulic e brake • Racing mirrors Pretty insane build back in the day. According to the PO, the build had over $125,000 in costs and upgrades. I've never priced them out, but I will say there is a lot of great work. The car is rock solid in itself. Rebuilding the original 2.0 would cost some money, as would removing and replacing many other parts to bring it back close to original. If the 3.6 engine and all of the performance parts were taken off, is there a market for it. I am just trying to gauge the market to see if my restoration cost could be offset with the sale of the parts. I simply do not know that space well. Any guesses? My other avenue might be a very reputable restoration shop (IMG:style_emoticons/default/first.gif) who would do the makeover in exchange for all of the parts. Could be a deal for someone. But I win too as my 914-6 is more valuable in original build. Thanks. |
Jonathan Livesay |
Sep 4 2014, 10:53 AM
Senior Member Group: Members Posts: 744 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
On the other hand it is a noble ambition to return a rare car such as that to stock condition. To show that my heart is in the right place, I would give you 2 grand for all that old junk you have to take off in order to restore it properly. That should get you started finding the right stuff. (IMG:style_emoticons/default/evilgrin.gif)
Lo-Fi Version | Time is now: 22nd December 2024 - 02:06 AM |
