Gas Tank Adventures, Tank out, stripping paint... |
boxsterfan |
Sep 6 2014, 06:40 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, I start the process of replacing my fuel pump today (which has been relocated up front by PO). So I got the tank out and it was starting to look pretty "rusty". So I figured I woul attempt to strip it down and repaint it. I have gotten most of the paint stripped off, but how am i going to get some/all of this surface rust off?
Any good radiator shops in San Ramon area I could drop it off to have someone finish it for me this week? Note: the inside of the tank looks very good....as if someone re-did the tank sometime ago. Attached thumbnail(s) |
boxsterfan |
Sep 7 2014, 09:32 PM
A question about the "fuel sock". So I pretty much destroyed my sock (which was in bad shape anyways). I've got an order to put together for some 30R9, 9.5 to 8mm adapters and fuel sock
However, I can't seem to get that nut off of the 9.5mm supply pipe. Yes, i have removed it from the tank itself, but is it also supposed to come apart??? The return line pipe that goes into the tank came apart no problem after I removed it from the tank. |
Lo-Fi Version | Time is now: 28th September 2024 - 06:43 PM |
