Seat slides backward, seat adjustment |
Mike1981 |
Sep 10 2014, 07:30 AM
Member Group: Members Posts: 245 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: Southern California |
Hello
I just picked up a 1970 914 I was hoping for some advice please I seems as if the clutch pedal must be depressed all the way to the floor to avoid grinding However the seat is all the way back to the firewall When I move the seat forward my legs can easily depress the pedal as well as the reach to the gearshifter is better. The only problem I have is when pushing in on the clutch the seat detaches from its setting and slides all the way back I took the seat out oiled the rails and it slides easily by hand Once I put pressure on it, the seat will again snap out of it setting and slide back Has anyone had this happen Could anyone offer a solution? Thanks Mike |
barefoot |
Sep 10 2014, 10:12 AM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The seat adjustment lever is spring loaded so it will secure the seat in the chosen position once you release the adjust lever. One of mine was broken ( a lever type spring) so I replaced it with a small coil spring I had laying around and it now latches OK.
Remove the seat and you will see where the lever spring is supposed to go. You can probably find a spring that will work on McMaster Carr. New add: BTW, there is a catch on the opposite side of the rtrack that prevents the seat from bieng fully slid off the track. gotta shove a long flat blade screwdriver down that track to dis-engage this spring loaded catch to allow full seat removal. An alternate is to unscrew the 4 bolts that hold the seat mechanism to the floor, then you can see everything from the undeerside. Barefoot |
Lo-Fi Version | Time is now: 27th December 2024 - 10:43 AM |
