> I need a radiator for my SBC conversion, Ideas? Part numbers?
pete
post Jun 21 2011, 10:52 AM
I need to purchase a radiator for my SBC conversion and am in need of some suggestions/part numbers. JEGS? Also, will need a over flow canister and hoses.
post Sep 10 2014, 04:00 PM
I would think it's too small plus square tubing does not have the best flow characteristics. If it were me (and it's not (IMG:style_emoticons/default/biggrin.gif) ) and I had exhausted all other means I would buy some larger hose and run it the easiest, fastest route just to confirm your suspicion.
BRAVE_HELIOS
post Sep 10 2014, 08:01 PM
"Knowledge speaks, wisdom listens"
Did some research this evening. Found that mounting the temp sensor in the intake next to the t-stat is a good location and gives the best indication if the cooling system is working correctly. So much for what the Griffin sales rep told me. I also found out that sometimes the threaded pipe adapter that the sensor is screwed into (then screwed into the manifold) was shrouding the sensor part of the sending unit rather than placing the sensor directly in the path of coolant flow. I need to confirm whether my sensor is completely in the flow path of the coolant or if it is partially or completely shrouded by the threaded pipe adapter. Look like next will be the coolant lines themselves.
QUOTE(76-914 @ Sep 10 2014, 04:00 PM) *
pete   I need a radiator for my SBC conversion   Jun 21 2011, 10:52 AM
Andyrew   Budget? You could build a radiator system from ...   Jun 21 2011, 11:02 AM
pete   Budget? You could build a radiator system from ...   Jun 21 2011, 12:46 PM
messix   from s10 v8 conversions they're using a stock ...   Jun 21 2011, 12:52 PM
andys   The only real semi-bolt-in system that I know of i...   Jun 21 2011, 01:13 PM
BIGKAT_83   My favorite C&R Radiator comes in a 14x27.5...   Jun 21 2011, 01:53 PM
joefri187   I need to purchase a radiator for my SBC conversi...   Jun 21 2011, 02:00 PM
pete   [quote name='pete' post='1497484' date='Jun 21 20...   Jun 21 2011, 02:20 PM
Andyrew   Joe, Thats a nice looking setup! Nice shee...   Jun 21 2011, 02:10 PM
Andyrew   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 02:15 PM
BIGKAT_83   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 04:19 PM
Andyrew   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 11:01 PM
joefri187   Here are a couple more pics... The radiator is fl...   Jun 21 2011, 02:55 PM
pete   Here are a couple more pics... The radiator is f...   Jun 22 2011, 01:18 PM
matthepcat   Fluidyne built one custom to my specs using the Pa...   Jun 21 2011, 03:25 PM
BRAVE_HELIOS   In my setup I went with a Giffin radiator, model 1...   Jun 21 2011, 05:52 PM
pete   In my setup I went with a Giffin radiator, model ...   Jun 22 2011, 01:02 PM
BRAVE_HELIOS   In my setup I went with a Giffin radiator, model 1...   Jun 23 2011, 05:36 PM
BRAVE_HELIOS   Hey all, I've had my setup in place for a whi...   Sep 10 2014, 02:41 PM
jcd914   It's all relative. When I needed a pair of fa...   Jun 22 2011, 10:41 AM
Andyrew   Pete, You wire them yourself, Typically on a swi...   Jun 22 2011, 01:25 PM
joefri187   Andrew nailed it.... I used a Derale adjustable f...   Jun 22 2011, 02:05 PM
andys   Andrew nailed it.... I used a Derale adjustable ...   Jun 22 2011, 02:16 PM
Andyrew   Good thing about those copper tubes is you can eas...   Jun 22 2011, 02:48 PM
joefri187   Good thing about those copper tubes is you can ea...   Jun 22 2011, 04:10 PM
drive-ability   Griffin double pass 9D-10682-01   Jun 22 2011, 10:11 PM
pete   Griffin double pass 9D-10682-01 Hi, I tried fin...   Jun 23 2011, 08:57 AM
drive-ability   Griffin double pass 9D-10682-01 Hi, I tried fi...   Jun 23 2011, 09:05 PM
pete   Griffin double pass 9D-10682-01 That's an a...   Jun 23 2011, 09:56 AM
andys   I used the AFCO 80133N which is available from Sum...   Jun 23 2011, 10:00 AM
ChristopherB   Does this thread, and these different set ups appl...   Mar 15 2013, 08:08 AM
bulitt   If you purchase a short enough radiator you can in...   Mar 15 2013, 08:23 AM
boxstr   It seems that the radiator has always been the Ach...   Mar 15 2013, 09:24 AM
pete   I can't believe I still haven't procured t...   Mar 15 2013, 09:30 AM
slothness   Don't skimp on cooling, re-read your old threa...   Mar 15 2013, 09:52 AM
ChristopherB   Does the set up differ depending on the engine use...   Mar 15 2013, 02:49 PM
kg6dxn   As a rule of thumb: You should use a radiator with...   Mar 15 2013, 05:12 PM
76-914   I would think it's too small plus square tubin...   Sep 10 2014, 04:00 PM
BRAVE_HELIOS   Did some research this evening. Found that mountin...   Sep 10 2014, 08:01 PM
Chris H.   Yeah that square tubing size sounds very small for...   Sep 10 2014, 08:37 PM
Mike Bellis   Temp sensor should be on the engine to know how ho...   Sep 10 2014, 10:13 PM
speed metal army   Don't forget flow! The rad needs to be big...   Sep 10 2014, 10:30 PM
Mike Bellis   Don't forget flow! The rad needs to be bi...   Sep 10 2014, 11:20 PM
CptTripps   I used an aluminium double-pass VW Scirocco radiat...   Sep 11 2014, 09:51 AM
mikesmith   Not certain about Mike's setup, but I have the...   Sep 12 2014, 02:25 PM
- Lo-Fi Version Time is now: 12th April 2025 - 02:11 AM
