what is this, ideas? |
jacksun |
Sep 14 2014, 02:16 PM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
pilothyer |
Sep 14 2014, 02:44 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
This one pictured is a thermo switch.......the thermo/time switch was used on 75 & 76 models which included a heater that limited the time of the function of the switch. The function of the switch is to provide ground to the cold start valve when it is really, really cold outside......................Put it in the freezer overnight and check for continuity between the terminal end and anywhere on the body of the switch.........You will most likely see that it never gets cold enough in your part of the country to even activate the cold start valve.
Lo-Fi Version | Time is now: 14th January 2025 - 07:07 PM |
