itsmagic |
Newbie ![]() Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 ![]() |
My 1972 1.7 914 recently decided to not start. I quickly noticed that the fuel pump is not running briefly like it should after the ignition key is turned. I verified that the relays on the relay board (Master, Fuel Pump, Blower) are all good by trying them on the headlight motors. I then verified that the two fuses on the relay board are good. Next, I popped the cap on the fuel pump relay and pressed it... the fuel pump runs when I do this. (The car will then start and run for a few seconds if I start it). Sooooo, I am at a loss... The fuel pump is fine, relay board is fine, relays are fine... what could be causing the fuel pump to not activate? Thank you for any advice. Wayne
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
I AM GOING THROUGH THE EXACT SAME THING as Wayne, who started this thread. (IMG:style_emoticons/default/sad.gif)
I thought it was a bad relay board, and have tried several other boards without finding my fix (Thanks Bruce for sending them!). I just learned about and tried the exposed relay test, and it did work, which means my relay board should be fine. With the relay innards exposed, I turned the key in the ignition to ON then pressed the relay and the fuel pump started running. I have also cleaned all the relay connections on the board, cleaned the relays, tried several working relays, and bending the relay prongs for a tighter fit. Still no power to the fuel pump! (IMG:style_emoticons/default/dry.gif) Does this mean it's time to swap out and try a new ECU brain?? I've been driving the 914 for over a week with the fuel pump wired directly to the battery. I have to unhook the battery every time I park. Is using a modified relay, one that is "always on," a bad idea for a temporary fix?? Seems like it would be the same thing as I have now (pump always on when car is going) but would mean I don't have to unhook the battery every time (and I could use the OEM pump electrical connection/wiring). Thanks in advance for more advice and tips (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 10:17 AM |
