> car is bucking under acceleration...any ideas?
era vulgaris
post Aug 27 2014, 02:04 PM
J is for Genius
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first?
era vulgaris
post Sep 15 2014, 11:47 AM
J is for Genius
Aha! i finally got it. After a couple weeks or whatever of dealing with this, and after cleaning the dizzy, cleaning every electrical contact I could find, after replacing the fuel filter, and after thinking I had a bad intake air temp sensor, and having nothing permanently fix the problem...I finally figured the issue out!
I decided to clean all the multi pin connectors on the relay board today, and when I went to unhook the negative battery terminal, the clamp broke off of the main ground wire that connects to the chassis. There were probably only a couple wires of the multi core cable still attached to the clamp, which would've not been enough to handle the full current all the electronics needed. Probably on occasion the wire would move close enough to the connector to make decent contact for full power, and then move away again when I'd lose power.
Got a new connector on there and the car is GOLDEN! (IMG:style_emoticons/default/aktion035.gif) Full power under all driving conditions, and everything on the car seems to be working better.
Moral of the story: check the obvious shit first before diving into the complex stuff!
dknechtly
post Sep 15 2014, 12:16 PM
Yellow 914
Geesh, thanks for posting the solution. That's probably a lesson learned for a lot of us! Glad all is now well.
era vulgaris   car is bucking under acceleration...any ideas?   Aug 27 2014, 02:04 PM
Mike Bellis   sounds like a lack of fuel.   Aug 27 2014, 02:50 PM
jt914-6   When you get the bucking worked out check your mot...   Aug 27 2014, 03:23 PM
Rand   Don 't know if the TPS would cause bucking to ...   Aug 27 2014, 03:45 PM
wndsnd   Car still have the Djet? Has the tank ever been c...   Aug 27 2014, 03:45 PM
era vulgaris   Motor mounts and trans mounts are still good. TPS...   Aug 27 2014, 04:32 PM
brp986s   Motor mounts and trans mounts are still good. TP...   Aug 27 2014, 07:31 PM
era vulgaris   Any chance a dying fuel pump would cause this? Ju...   Aug 27 2014, 04:52 PM
Mike Bellis   Any chance a dying fuel pump would cause this? J...   Aug 27 2014, 06:52 PM
scotty b   Check all of the vaccum lines. there is one in par...   Aug 27 2014, 07:18 PM
jasons   When my 2.0 did this, it was the trigger points in...   Aug 27 2014, 07:21 PM
mepstein   Mine did this. Did a LOT of things to try to fix b...   Aug 27 2014, 07:52 PM
warrenoliver   Could be a loose ground wire on your distributor p...   Aug 27 2014, 09:16 PM
era vulgaris   Check all of the vaccum lines. there is one in pa...   Aug 27 2014, 09:44 PM
BeatNavy   I think it's probably worth reading this thre...   Aug 28 2014, 04:30 AM
76-914   What's your fuel pressure?   Aug 27 2014, 09:46 PM
The Cabinetmaker   I'm surprised that no one has mentioned the f...   Aug 28 2014, 04:03 AM
dknechtly   There's a lot of good advice here. Make sure ...   Aug 28 2014, 07:55 AM
era vulgaris   So first I cleaned every contact I could find in b...   Aug 28 2014, 01:29 PM
Phoenix914   :headbanger: :Qarl: :driving:   Aug 28 2014, 03:43 PM
The Cabinetmaker   don't you love the simple fixes   Aug 28 2014, 04:19 PM
era vulgaris   Definitely! :Qarl:   Aug 28 2014, 04:40 PM
era vulgaris   Celebrated too soon :( Went for another drive t...   Aug 28 2014, 09:44 PM
PancakePorsche   Celebrated too soon :( Went for another drive ...   Aug 29 2014, 02:33 AM
era vulgaris   Got a friend bringing over his fuel pressure gauge...   Sep 2 2014, 05:35 PM
Rand   Disregard that since you have a carb now. You don...   Sep 2 2014, 06:20 PM
era vulgaris   Disregard that since you have a carb now. You do...   Sep 2 2014, 07:12 PM
r_towle   I would suggest a few things. A new fuel tank sock...   Sep 2 2014, 09:47 PM
era vulgaris   I would suggest a few things. A new fuel tank soc...   Sep 3 2014, 09:05 AM
BeatNavy   Is there a good guide somewhere to pulling and c...   Sep 3 2014, 09:22 AM
era vulgaris   I say again (from page 1 of this thread), you may...   Sep 3 2014, 10:49 AM
BeatNavy   [quote name='BeatNavy' post='2081511' date='Sep 3...   Sep 3 2014, 01:24 PM
914_teener   I would suggest a few things. A new fuel tank soc...   Sep 2 2014, 10:22 PM
era vulgaris   Couple of extra things I thought of: Check your...   Sep 3 2014, 09:08 AM
914_teener   :agree: I assumed you had already done this. Ge...   Sep 3 2014, 09:47 AM
BeatNavy   Sorry, a couple more things to note: you probably...   Sep 3 2014, 02:08 PM
era vulgaris   Sorry, a couple more things to note: you probabl...   Sep 3 2014, 04:05 PM
BeatNavy   Sorry, a couple more things to note: you probab...   Sep 3 2014, 04:18 PM
jacksun   hi, maybe the below will help? "Throttle Swi...   Sep 3 2014, 07:52 PM
era vulgaris   Aha! i finally got it. After a couple weeks ...   Sep 15 2014, 11:47 AM
BeatNavy   check the obvious shit first before diving into t...   Sep 15 2014, 11:56 AM
era vulgaris   But at least you learned a lot of things that co...   Sep 15 2014, 01:10 PM
dknechtly   Geesh, thanks for posting the solution. That...   Sep 15 2014, 12:16 PM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 02:46 AM
