Rebuilding my front end, Calling our Suspension experts for comments and suggestions |
draganc |
Sep 12 2014, 06:43 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody!
I’m rebuilding my front suspension and already did most of my research here on the forum. Just wanted to double check with the forum before I buy the wrong parts and powder-coating. Up front, some car/driver information: ’75 2.0 (upgraded to 2056), weekend driver MAYBE some AX/track (only for fun). What I have done so far: - small hell-hole repair and a 2x4” floor patch, rest of the body is rust free - yeah I know, urban legend (IMG:style_emoticons/default/biggrin.gif) - Tangerine heim rods welded in and trail-arm bushings installed. - Rear coil over Bilsteins setup with Eibach 125lbs - Original rear and front sway bar (new bushings) - Inspected front shock tower rubber. Looks excellent w/o cracks, almost like new. What I’m planning to do and some questions: - Powder coat front suspension HW - Install new ball joint and turbo tie rods - Install new calipers, pads and lines (steel and rubber) - Rebel racing front bushings - Upgrade std./old Boge inserts to Bilstein. Should I go for the HD or Sport type? What’s the difference? Does it make any sense to “upgrade” the torsion bars also, in order to match the rear 125lbs springs? - Run ATS wheels (7x15 ET30) with 195 tires (I don’t want to roll the fenders). Any tire (summer only) recommendations? - Bump steer kit If I install the washer/longer screw kit (between cross bar and rack) will/can it have a negative impact if don’t go low “enough”? - Align front and rear wheels. Thanks for your inputs! (IMG:style_emoticons/default/beerchug.gif) Dragan PS: I looked high and low on bilsteinus.com to find out if my rear shock (1610 B46 0179 H1 Type 20) is a HD or Sport version. Can somebody confirm the type? I thinks it’s HD but not sure. |
draganc |
Sep 15 2014, 04:05 PM
Thanks a lot for the phone training and the summary!
Lo-Fi Version | Time is now: 27th December 2024 - 07:24 PM |
