> eBrake won't set, Took it apart- see pics Monday
jim_hoyland
post Sep 13 2014, 08:51 PM
Get that VIN ?
It's a late car; when I pull up on the eBrake handle it doesn't set. It will go back down to the floor. Is a part sticking ?
bdstone914
post Sep 14 2014, 04:28 PM
bdstone914
Here is the layout of the parts.
jim_hoyland
post Sep 14 2014, 06:36 PM
Get that VIN ?
QUOTE(bdstone914 @ Sep 14 2014, 03:28 PM) *
Which parts are causing the handle to not catch ?
SLITS
post Sep 16 2014, 01:10 PM
"This Utah shit is HARSH!"
QUOTE(jim_hoyland @ Sep 14 2014, 05:36 PM) *
Jim,
From the pic in the post, note that the rod goes over the end of the pawl. No spring is needed down there as the rod is spring loaded.
Sharpen the cut in the pawl and be done with it.
jim_hoyland
post Sep 16 2014, 03:46 PM
Get that VIN ?
QUOTE(SLITS @ Sep 16 2014, 12:10 PM) *
Jim,
The pawl teeth are really worn; Bruce is sending a replacement lever assembly. Thanks for the info... (IMG:style_emoticons/default/smile.gif)
jim_hoyland   eBrake won't set   Sep 13 2014, 08:51 PM
partwerks   It's a late car; when I pull up on the eBrake...   Sep 13 2014, 08:53 PM
jim_hoyland   It's a late car; when I pull up on the eBrak...   Sep 13 2014, 09:02 PM
ndfrigi   [quote name='partwerks' post='2085775' date='Sep ...   Sep 13 2014, 09:10 PM
Cap'n Krusty   It's a late car; when I pull up on the eBrak...   Sep 14 2014, 09:01 AM
mepstein   mine wasn't catching. I took it out of the car...   Sep 13 2014, 09:07 PM
bdstone914   It's a late car; when I pull up on the eBrake...   Sep 13 2014, 09:17 PM
jim_hoyland   It's a late car; when I pull up on the eBrak...   Sep 13 2014, 09:37 PM
914_teener   Bruce, Sounds like the spring is Kaput. I don...   Sep 13 2014, 09:37 PM
bdstone914   Bruce, Sounds like the spring is Kaput. I don...   Sep 13 2014, 09:53 PM
76-914   Jim, unscrew the blk plastic knob and look. Sounds...   Sep 14 2014, 07:26 AM
jim_hoyland   Unscrewed the button and pulled the spring; spring...   Sep 14 2014, 08:21 AM
Cap'n Krusty   Unscrewed the button and pulled the spring; sprin...   Sep 14 2014, 10:17 AM
mepstein   Unscrewed the button and pulled the spring; sprin...   Sep 14 2014, 04:13 PM
jim_hoyland   A seat removal is required ?   Sep 14 2014, 10:35 AM
mepstein   A seat removal is required ? eisier to do with t...   Sep 14 2014, 12:23 PM
bdstone914   [quote name='jim_hoyland' post='20859...   Sep 14 2014, 03:52 PM
worn   You are going to have to replace the handle. I ...   Sep 15 2014, 04:21 PM
Dave_Darling   Maybe not, but it makes access easier, and it take...   Sep 14 2014, 12:20 PM
bdstone914   Here is the layout of the parts.   Sep 14 2014, 04:28 PM
jim_hoyland   Here is the layout of the parts. Which parts a...   Sep 14 2014, 06:36 PM
914_teener   Here is the layout of the parts. Which parts ...   Sep 14 2014, 09:43 PM
jim_hoyland   [quote name='jim_hoyland' post='2086113' date='Se...   Sep 15 2014, 06:37 AM
SLITS   Here is the layout of the parts. Which parts ...   Sep 16 2014, 01:10 PM
jim_hoyland   [quote name='jim_hoyland' post='2086113' date='Se...   Sep 16 2014, 03:46 PM
jim_hoyland   Is the rod and piece on the right end one piece ?   Sep 14 2014, 06:31 PM
Cap'n Krusty   No. The Cap'n   Sep 14 2014, 06:34 PM
jim_hoyland   Dissassembled the handle from the body. The rod an...   Sep 15 2014, 02:32 PM
jim_hoyland   Reassembled after inspection; looks like the teeth...   Sep 15 2014, 03:29 PM
worn   Reassembled after inspection; looks like the teet...   Sep 15 2014, 04:18 PM
Cap'n Krusty   Does the pawl move with the rod? (The rod and paw...   Sep 15 2014, 04:07 PM
worn   It's a late car; when I pull up on the eBrake...   Sep 15 2014, 04:15 PM
jim_hoyland   I can' detach the assembly from the cable at t...   Sep 15 2014, 04:33 PM
SLITS   I can' detach the assembly from the cable at ...   Sep 15 2014, 05:54 PM
jim_hoyland   I have a late (75) handle; in reading a pat postin...   Sep 16 2014, 07:21 AM
MoveQik   Jim, I think this is all a sign that you let your ...   Sep 16 2014, 03:53 PM
jim_hoyland   Jim, I think this is all a sign that you let your...   Sep 16 2014, 06:15 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 06:04 PM
