How important to remove tunnel cables? |
doug_b_928 |
Sep 16 2014, 07:35 PM
Senior Member Group: Members Posts: 712 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I have my car stripped down with the exception of the wiring harness and the stuff/cables in the tunnel (fuel lines are in there too but will be replaced). In the pics I've seen on this forum it seems that, in most cases, the tunnel cables are completely removed. I haven't tried yet but in looking at it it seems like it might be very difficult to reinstall the cables. Is that the case? If so, and probably a really dumb question, why do they need to be removed?
cn2800 |
Sep 16 2014, 07:46 PM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
Having just done exactly what you're talking about, I'll offer my two cents. The speedometer and clutch cables were a cinch to remove. For the accelerator and heater cables, I had a little trouble. I had to slightly straighten the left-hand heater cable tube in the engine compartment to allow the straight, stiff end part to fit through towards the cab. For the accelerator cable, I wound up cutting the stiff, threaded end off in the cab and pulling the cable through to the rear - it also wouldn't fit through the curve of the tube in the engine compartment. I figured if I'm going to install a new one, it wouldn't matter, and I could more easily straighten the tube without the cable in the way.
doug_b_928 |
Sep 16 2014, 08:19 PM
Having just done exactly what you're talking about, I'll offer my two cents. The speedometer and clutch cables were a cinch to remove. For the accelerator and heater cables, I had a little trouble. I had to slightly straighten the left-hand heater cable tube in the engine compartment to allow the straight, stiff end part to fit through towards the cab. For the accelerator cable, I wound up cutting the stiff, threaded end off in the cab and pulling the cable through to the rear - it also wouldn't fit through the curve of the tube in the engine compartment. I figured if I'm going to install a new one, it wouldn't matter, and I could more easily straighten the tube without the cable in the way. Hmmm......sounds like it will be fun getting the new ones in. Did you pull the wiring harness at the firewall too? |
cn2800 |
Sep 16 2014, 08:53 PM
[/quote] I have removed the wiring harness from the car. I don't recall where I read it (probably on this forum), but the instructions said to both pull and install the harness starting from the point on the tunnel next to the shifter. I was able to do it without removing any connectors from the harness. Patience and cleverness are key. Treat feeding the wires through the rear firewall (to the interior) like a Chinese puzzle. Sometimes you have to stop pulling the whole harness, and feed an individual wire or two through to make it work. I should add that since I was going to replace the 'snorkel', I cut it in half and pulled it off from inside the engine compartment. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:54 AM |
