> Seat slides backward, seat adjustment
Mike1981
post Sep 10 2014, 07:30 AM
Hello
I just picked up a 1970 914
I was hoping for some advice please
I seems as if the clutch pedal must be depressed all the way to the floor to avoid grinding
However the seat is all the way back to the firewall
When I move the seat forward my legs can easily depress the pedal as well as the reach to the gearshifter is better.
The only problem I have is when pushing in on the clutch the seat detaches from its setting and slides all the way back
I took the seat out oiled the rails and it slides easily by hand
Once I put pressure on it, the seat will again snap out of it setting and slide back
Has anyone had this happen
Could anyone offer a solution?
Thanks
Mike
malcolm2
post Sep 17 2014, 05:21 PM
a fresh one could solve the problem.
I have taken mine out several times. I have the opposite problem, the driver's seat just will not move. I am tall so back is good for me. I LET the wife drive the other day and it took alot of work to get it to move to the closest setting.... long story-short,
When you take your seat off of the rails, is there a leaf spring on one of the rails that is attached to the seat? that is what keeps the seat from adjusting all the way off (forward). And when pushed up it allows the seat to come off when adjusted all the way forward. Could be an issue if it is gone.
without having it in front of me, it seems that your HANDLE is not engaging in the holes once you set the seat. Does the handle have the little square blocks in it that go in the square holes?
Clark
- Lo-Fi Version Time is now: 27th December 2024 - 10:03 AM
