Question about door jam/quarter panel joint, is it welded or braized? |
carl k |
Sep 15 2014, 09:49 AM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
nathansnathan |
Sep 18 2014, 09:39 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
The problem with welding by the seam is that it's not going to be clean metal between. Best case scenario, you have new weld through primer only in between. That stuff doesn't work that well for mig or tig - best to use a spot welder. You can't clean up between afterward, so the joint becomes a weak spot for more rust to form.
Butt welding is welding 2 pieces butted up to one another - there's no double layers involved. Just back the weld and there's no danger of blow through. Do it where it's single layered. |
Lo-Fi Version | Time is now: 27th December 2024 - 04:46 PM |
