how do i adjust parking brake |
rosenfe |
Sep 17 2014, 07:40 PM
Senior Member Group: Members Posts: 564 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? |
bdstone914 |
Sep 18 2014, 06:12 AM
bdstone914 Group: Members Posts: 4,670 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? Do disconnect the cable at the caliper. I think you move the nuts up the cable to reduce slack. You can pull on the open park of the cable and feel the slack. Tighten until you have almost no slack. Do this with the rear wheels off the ground. Spin each wheel to see that the pads are not dragging. You move the adjusting screws until the lever on the caliper starts to move then back off. Test by pulling the e brake handle. It should have resistance with little play. |
rosenfe |
Sep 18 2014, 09:13 AM
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? Do disconnect the cable at the caliper. I think you move the nuts up the cable to reduce slack. You can pull on the open park of the cable and feel the slack. Tighten until you have almost no slack. Do this with the rear wheels off the ground. Spin each wheel to see that the pads are not dragging. You move the adjusting screws until the lever on the caliper starts to move then back off. Test by pulling the e brake handle. It should have resistance with little play. thanks for the info,but i still dont see how moving nuts on threaded cable tighten slack.i will check it out and move nuts either direction and see what impact that has on ebrake lever at caliper.i will keep cable connected to caliper ,so i can see adjustment effect with nuts. |
JFJ914 |
Sep 18 2014, 09:33 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? Do disconnect the cable at the caliper. I think you move the nuts up the cable to reduce slack. You can pull on the open park of the cable and feel the slack. Tighten until you have almost no slack. Do this with the rear wheels off the ground. Spin each wheel to see that the pads are not dragging. You move the adjusting screws until the lever on the caliper starts to move then back off. Test by pulling the e brake handle. It should have resistance with little play. thanks for the info,but i still dont see how moving nuts on threaded cable tighten slack.i will check it out and move nuts either direction and see what impact that has on ebrake lever at caliper.i will keep cable connected to caliper ,so i can see adjustment effect with nuts. Moving the cable sheath in or out by loosening the lock nut adjusts the sheath length. Moving the sheath out will tighten the cable. Do not disconnect the cable from the caliper. |
rosenfe |
Sep 18 2014, 11:06 AM
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? Do disconnect the cable at the caliper. I think you move the nuts up the cable to reduce slack. You can pull on the open park of the cable and feel the slack. Tighten until you have almost no slack. Do this with the rear wheels off the ground. Spin each wheel to see that the pads are not dragging. You move the adjusting screws until the lever on the caliper starts to move then back off. Test by pulling the e brake handle. It should have resistance with little play. thanks for the info,but i still dont see how moving nuts on threaded cable tighten slack.i will check it out and move nuts either direction and see what impact that has on ebrake lever at caliper.i will keep cable connected to caliper ,so i can see adjustment effect with nuts. Moving the cable sheath in or out by loosening the lock nut adjusts the sheath length. Moving the sheath out will tighten the cable. Do not disconnect the cable from the caliper. i dont get it,how does unlocking the 2- 17mm nuts on brake cable increase or decrease cable length.the nuts move on the threaded cable,but cable doesnt move to tighten or loosen. i dont see a sheath,just a solid cable with threaded end and locking nuts. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:52 PM |
