1975 2.0, Engine rebuild |
DavidSweden |
Sep 18 2014, 10:16 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am going to rebuild my 2.0 GC engine. The car was originally fitted with the smog stuff removed by PO, also has the original FI
Question; I want to get more power from the engine without spending a lot of $ and I want to do the work myself. All suggestions welcome, thanks |
Bob L. |
Sep 18 2014, 11:08 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Swap out the 94mm cylinders and pistons for 96mm. That will give you a 2056mm displacement engine.Then you either re-tune the MPS and keep the D-jet or go with carbs and a cam swap. It's a pretty popular "upgrade". Just check the new P's&C's for run out. Some brands can be hit or miss.
Lo-Fi Version | Time is now: 28th December 2024 - 01:16 AM |
