> 1975 2.0, Engine rebuild
DavidSweden
post Sep 18 2014, 10:16 AM
I am going to rebuild my 2.0 GC engine. The car was originally fitted with the smog stuff removed by PO, also has the original FI
Question;
I want to get more power from the engine without spending a lot of $ and I want to do the work myself.
All suggestions welcome, thanks
Bob L.
post Sep 18 2014, 11:08 AM
Swap out the 94mm cylinders and pistons for 96mm. That will give you a 2056mm displacement engine.Then you either re-tune the MPS and keep the D-jet or go with carbs and a cam swap. It's a pretty popular "upgrade". Just check the new P's&C's for run out. Some brands can be hit or miss.
DavidSweden
post Sep 18 2014, 11:58 AM
QUOTE(Bob L. @ Sep 18 2014, 09:08 AM) *
Bob,
Sorry but what is MPS and will I be limited by keeping the original D-Jet?
Bob L.
post Sep 18 2014, 12:15 PM
QUOTE(DavidSweden @ Sep 18 2014, 12:58 PM) *
Bob,
The "manifold pressure sensor". It should be mounted just below the stock battery location. About the size of an orange. It will have 1 vacuum hose going to it. It is calibrated for 1.7, 1.8 or 2.0 as needed. Once tuned it should be a fairly stable setup.
I'm no expert but I believe that the carb and cam swap will net you more power but there is also a lot of tuning to be done. Carb's also require more maintenance.
There are lots of members who have done both. They will chime in.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 01:41 AM
