rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
on my 73,i recently installed rebuilt rear calipers,set venting.now hand brake lever will not fully engage parking brake,it ratches too high,too much slack..im assumong previous calipers were stuck and gave very little motion to hand brake lever.i undid 2 adjusting nuts under neath at cable,but not sure how to adjust slack.do i need to undo cable from caliper,then adjust?what direction do i turn cable? |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Less likely problem, but last time I assembled cables I had too much play and
eventually found that one cable, where it went through the trailing arm bracket, the 'C' clip was not in the groove. Didn't look obviously different, but when the cable was pulled it allowed the cable to move rather than caliper arm. |
rosenfe |
Less likely problem, but last time I assembled cables I had too much play and eventually found that one cable, where it went through the trailing arm bracket, the 'C' clip was not in the groove. Didn't look obviously different, but when the cable was pulled it allowed the cable to move rather than caliper arm. definitely a possibility |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:22 PM |
