passenger side back caliper, help |
hndyhrr |
Sep 19 2014, 01:47 PM
Senior Member Group: Members Posts: 588 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
1970,1.7
my back passenger side brake is hanging up. found that the ebrake arm on caliper will not travel the distance it should, pulled the little gear from inside where you set the vent clearance and the teeth are chewed up and a couple missing. where can i get this one and would this cause the arm not to move??????? also would the little gear from a vw work????? (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/headbang.gif) |
hndyhrr |
Sep 19 2014, 02:51 PM
here is pic of gear, can I cut it off and then use stainless steel washer behind it when i put it back in??? |
Lo-Fi Version | Time is now: 28th December 2024 - 02:23 AM |
