Strut type, What is it |
DavidSweden |
Sep 20 2014, 12:18 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I got some 911 struts to do a 5 lug conversion. The struts came with rotors, discs, hubs and M calipers.
When I unskrewed the top of the strut I got a surprise, instead of an insert damper the strut contained a piston and a lot of oil. The only number I found on the strut was L 655.01 Question: Does anyone know what year the strut was manufactured and what type of insert damper do I need to install? Dont suppose its possible to refill and use existing piston? Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.3.jpg) |
Harpo |
Sep 21 2014, 10:13 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Yes you can although I forget exactly what type Of Oil that I used.
David |
DavidSweden |
Sep 21 2014, 10:48 AM
Yes you can although I forget exactly what type Of Oil that I used. David David, Thanks for the reply. You say you have refilled the damper. Did you fill half way or more and did you replace the O rings? Appreciate if you could give me some pointers so I can avoid mistakes |
Cap'n Krusty |
Sep 21 2014, 02:01 PM
Yes you can although I forget exactly what type Of Oil that I used. David David, Thanks for the reply. You say you have refilled the damper. Did you fill half way or more and did you replace the O rings? Appreciate if you could give me some pointers so I can avoid mistakes Once you've replaced all the internal seals, you can add the correct quantity of shock oil (which is very thin and smells kinda like fish) and reassemble the strut. However, the seals are probably NLA, and the correct quantity of the proper oil may be difficult to determine. There's a small chance the instructions might be in an early version of the workshop manual, or possibly the 911 manual, but I don't recall ever seeing the specs. The seals and o-rings may not be available anywhere, and a parts breakdown is NOT in the PET, meaning Porsche probably never furnished them as spare parts. The Cap'n |
Lo-Fi Version | Time is now: 27th December 2024 - 09:58 PM |
