1972 1.7 - Fuel pump not starting when key is turned, Problem with fuel pump |
itsmagic |
Aug 8 2014, 10:46 AM
Newbie Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 |
My 1972 1.7 914 recently decided to not start. I quickly noticed that the fuel pump is not running briefly like it should after the ignition key is turned. I verified that the relays on the relay board (Master, Fuel Pump, Blower) are all good by trying them on the headlight motors. I then verified that the two fuses on the relay board are good. Next, I popped the cap on the fuel pump relay and pressed it... the fuel pump runs when I do this. (The car will then start and run for a few seconds if I start it). Sooooo, I am at a loss... The fuel pump is fine, relay board is fine, relays are fine... what could be causing the fuel pump to not activate? Thank you for any advice. Wayne
Chris Pincetich |
Sep 22 2014, 11:24 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
There was no ground signal at the #3 connection of the 4-pin plug. Adding a jumper to complete the ground circuit resulted in a working fuel pump! (IMG:style_emoticons/default/beerchug.gif)
I used the multimeter to check conductivity/connectivity to the ECU. From #3 connection on the 4-pin plug to the #19 spot on the ECU input there was a solid signal. The circuit seems to be good. BAD BRAIN?!?!?!? (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/headbang.gif) What's next? (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 10:39 AM |
