itsmagic |
Newbie ![]() Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 ![]() |
My 1972 1.7 914 recently decided to not start. I quickly noticed that the fuel pump is not running briefly like it should after the ignition key is turned. I verified that the relays on the relay board (Master, Fuel Pump, Blower) are all good by trying them on the headlight motors. I then verified that the two fuses on the relay board are good. Next, I popped the cap on the fuel pump relay and pressed it... the fuel pump runs when I do this. (The car will then start and run for a few seconds if I start it). Sooooo, I am at a loss... The fuel pump is fine, relay board is fine, relays are fine... what could be causing the fuel pump to not activate? Thank you for any advice. Wayne
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Chris,
Yes, If the wires and connections are good as you indicated, then the ECU has failed. It isn't giving the ground path that is needed. Temporarily you can run with a jumper from ground to the #3 pin. Just remember, the pump will run anytime the key is ON. Tom |
Lo-Fi Version | Time is now: 30th June 2024 - 11:05 AM |
