Thursday, 13 March 2025
> anyone played with boxster gauge cluster?
skeates
post Jul 29 2014, 09:57 PM
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
Dr Evil
post Sep 23 2014, 07:15 AM
Send me your transmission!
Not that it matters now, since you have been experiencing success with your interface using the Arduino, but what I was referring to with the use of the OE gauge guts was to place the guts behind the gauge face in place of the original, put the Boxter needle on the shaft of the OE unit, and then use the original tank sender. I see this as simple, but not nearly as much fun, nor elegant (IMG:style_emoticons/default/wink.gif) The problems I foresee doing this are possible length of shaft of OE too short, needle wont work on shaft, sweep ark of OE not same as Boxter and thus gauge face will not be correct measurement/needle deflection will be incorrect, OE guts will not fit.
With your initial start up causing needle bounce, is it possible to have a value programmed in to make the needle hold a value consistent with the E at start up? How bout Full and then is drops to actual? Is this bounce of the needle stop due to poor or no signal? Does the stock setup in a Boxter do this, or is this just due to your interface? How about a delay in the interface that allows it to power up before sending a signal to the gauge so that there is no "seizure" on start up?
skeates   anyone played with boxster gauge cluster?   Jul 29 2014, 09:57 PM
Dave_Darling   Depending on the year of Boxster/996, the answer a...   Jul 29 2014, 10:14 PM
jd74914   I would be highly surprised if the newer stuff did...   Jul 30 2014, 06:02 AM
stugray   If you have the pinouts, please post them. I have...   Jul 30 2014, 07:16 AM
skeates   If you have the pinouts, please post them. I hav...   Jul 30 2014, 02:48 PM
Mike Bellis   I'm running a 2000 VW cluster and it does comm...   Jul 30 2014, 07:45 AM
skeates   @ Dave_Darling: I figured anything 2004 or newer w...   Jul 30 2014, 02:45 PM
jd74914   You are running an Infinity? Which one? We looke...   Jul 31 2014, 07:41 AM
skeates   You are running an Infinity? Which one? We look...   Jul 31 2014, 10:19 AM
jd74914   You are running an Infinity? Which one? We loo...   Jul 31 2014, 11:23 AM
CptTripps   Looking forward to seeing progress. Those clusters...   Jul 31 2014, 09:14 AM
skeates   Ok, I bit the bullet and purchased a boxster gauge...   Sep 3 2014, 05:44 PM
skeates   The local hardware store was having a sale on the ...   Sep 3 2014, 05:52 PM
Dave_Darling   One thing I have heard that is important here, if ...   Sep 3 2014, 06:14 PM
skeates   One thing I have heard that is important here, if...   Sep 3 2014, 06:26 PM
skeates   So, until someone tells me this is cluttering up t...   Sep 15 2014, 01:07 PM
SirAndy   :trophy: That looks better than i thought it wou...   Sep 15 2014, 01:22 PM
purple505uk   So, until someone tells me this is cluttering up ...   Oct 26 2015, 02:07 PM
Dr Evil   Wow, very nice work :)   Sep 17 2014, 07:36 AM
Sleepin   Sweet! :popcorn:   Sep 17 2014, 08:49 AM
boxsterfan   Fuchin' awesome!!   Sep 17 2014, 09:05 AM
Dr Evil   Question, just say you have to rely on the engines...   Sep 17 2014, 09:22 AM
skeates   Question, just say you have to rely on the engine...   Sep 17 2014, 06:34 PM
timothy_nd28   It would be difficult to defeat the ECU communicat...   Sep 17 2014, 09:35 PM
skeates   It would be difficult to defeat the ECU communica...   Sep 19 2014, 03:43 PM
worn   It would be difficult to defeat the ECU communica...   Sep 19 2014, 07:13 PM
CptTripps   :agree: with Andy. This looks a TON better than I ...   Sep 18 2014, 08:45 AM
Dr Evil   Oooooo :) I like the splicing into the OE motor m...   Sep 19 2014, 03:47 PM
timothy_nd28   To see how this air core motor is wired internally...   Sep 19 2014, 04:07 PM
skeates   To see how this air core motor is wired internall...   Sep 19 2014, 04:45 PM
timothy_nd28   Ok. If you reset the board and have the fuel gauge...   Sep 19 2014, 07:53 PM
904svo   From the reading you have a stepper motor gas gaug...   Sep 19 2014, 08:14 PM
skeates   From the reading you have a stepper motor gas gau...   Sep 21 2014, 04:09 PM
skeates   Just finished taking some voltage readings on the ...   Sep 19 2014, 11:28 PM
timothy_nd28   Is the needle fixed at full level but the voltages...   Sep 19 2014, 11:35 PM
skeates   Is the needle fixed at full level but the voltage...   Sep 20 2014, 12:03 AM
Dr Evil   While I dig the scholastic effort in figuring out ...   Sep 20 2014, 08:04 AM
timothy_nd28   No, the voltages do not oscillate as in a motor, b...   Sep 20 2014, 08:08 AM
skeates   While I dig the scholastic effort in figuring out...   Sep 20 2014, 03:55 PM
Dr Evil   Fascinating. I have never heard of aircore gauges....   Sep 20 2014, 08:15 AM
timothy_nd28   In my signature, i did a write up on how to do a t...   Sep 20 2014, 08:57 AM
Dr Evil   Looked at it, bumped it :) Good stuff. Would the...   Sep 20 2014, 11:27 AM
timothy_nd28   Absolutely using the original sender, everything w...   Sep 20 2014, 11:48 AM
timothy_nd28   Absolutely using the original sender, everything w...   Sep 20 2014, 11:49 AM
Dr Evil   Badass!   Sep 20 2014, 12:20 PM
timothy_nd28   We will help you with the calculations needed for ...   Sep 20 2014, 04:49 PM
Dr Evil   The link on wiki has some suggestions for driver c...   Sep 20 2014, 05:20 PM
stugray   Great work! On a slightly related note: Just...   Sep 21 2014, 04:36 PM
skeates   The link on wiki has some suggestions for driver ...   Sep 22 2014, 12:37 AM
CptTripps   That's just bad ass....   Sep 22 2014, 07:59 AM
timothy_nd28   Awesome! Sorry for sending you down a wrong p...   Sep 22 2014, 11:20 AM
skeates   Awesome! Sorry for sending you down a wrong ...   Sep 22 2014, 12:05 PM
Scott S   Wow. I have never felt dumber. There are some smar...   Sep 22 2014, 12:01 PM
Philip W.   Wow. I have never felt dumber. There are some sma...   Sep 23 2014, 07:31 AM
Dr Evil   Not that it matters now, since you have been exper...   Sep 23 2014, 07:15 AM
ruby914   Nice work Skeates! The Boxter cluster up agai...   Sep 23 2014, 10:02 AM
skeates   Not that it matters now, since you have been expe...   Sep 23 2014, 10:57 AM
Dr Evil   All of my shit is in boxes in the back of a truck ...   Sep 23 2014, 05:52 PM
Chris914n6   Cluster fit doesn't look too far off. The loop...   Sep 25 2014, 02:27 AM
- Lo-Fi Version Time is now: 13th March 2025 - 08:31 AM
