Loose suspension nut... |
MikeM |
Sep 22 2014, 10:46 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I'm referring to the inner nut on the suspension ear ,inner end of pivot shaft.
Can anyone tell me why this nut always seems to loosen? Every time I put a wrench on it I can tighten it by about 1 turn. It tightens up, then a week later it's loose again? Car is a 74 2.0 liter, I have Eric's bushings in the trailing arm. Thanks!! Mike |
914_teener |
Sep 23 2014, 03:35 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If you got the hard replacement rubber bushings from PMB the bushing will sit "proud" of the control arm enough to be longer in OA length to the pivot shaft.
If you didn't grind them back to less than the pivot shaft length then the pivot shaft will have a hard time staying stationary relying just on the torque on the nut and the surface of the new bushing against the chassis mounting points. The serrations of the pivot shaft end are intended to lock against the suspension ear and the outer mount near the side valance. It could also be the "ear flex" but if you haven't done the above.....I doubt it. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:30 PM |
