Loose suspension nut... |
MikeM |
Sep 22 2014, 10:46 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I'm referring to the inner nut on the suspension ear ,inner end of pivot shaft.
Can anyone tell me why this nut always seems to loosen? Every time I put a wrench on it I can tighten it by about 1 turn. It tightens up, then a week later it's loose again? Car is a 74 2.0 liter, I have Eric's bushings in the trailing arm. Thanks!! Mike |
MikeM |
Sep 23 2014, 08:56 PM
Steve...thanks for the torque specs. Are you saying I should replace the nut?
Mike |
Steve |
Sep 23 2014, 10:19 PM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Steve...thanks for the torque specs. Are you saying I should replace the nut? Mike I just use locktite and tighten it as best I can. I have never had the inside one come loose. Only the outside when it wasn't torqued down. When it slipped it would make a klunking sound. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:03 PM |
