914ltd |
Member ![]() ![]() Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
I posted this last year, heating season is here again. These are big cracks, a tiny one you would not be able to hear would still be dangerous. These are not accident damaged. If you have a set on your car, grab the carbon monoxide detector from home and take a ride with the heat on and windows rolled up. There is a detector used in small aircraft also available. The last photo is how we now test for leaks using air pressure. Brad
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
If the exchangers are on the car, a simple battery powered CO detector is probably the best you can do. Even on units that test out good, isn't it cheap insurance to have one in the car?
Lo-Fi Version | Time is now: 18th June 2024 - 06:54 AM |
