Mikedrevguy |
Member ![]() ![]() Group: Members Posts: 87 Joined: 19-May 14 From: Medford, Or Member No.: 17,371 Region Association: Pacific Northwest ![]() |
Picked up a 76 2.0 for my better 1/2.
It's been off the road for the past -10 years. Motor spins freely and, reportedly, was rebuilt shortly before it was parked (which was due to physical limitations). Paint is heavily oxidized. Brakes were locked up, rotors rust covered. Car had been hit previously, and the resulting bondo has cracked pretty badly. Interior is nice, seats have no tears or holes. Dash has a couple cracks, but nothing overly grotesque. As I begin getting this back roadworthy, Am pulling fuel tank to be cleaned out thoroughly. Replacing all fuel and vacuum lines. Changing oil and trans fluid. Will go through brake system. See what's good. What's in need of replace or [email]repair. My question: where can I go for a list of what pieces parts are compatible from year to year in the 914. Interested in front and rear hoods, top, brake calipers - Or more specifically, I've a line on a 71 running complete parts car- what will cross over between a 71 and a 76? Thanks. I look forward to posting pics (when I get them and figure out how they work on this forum. Rev. |
Mikedrevguy |
Thought it might be the filter, but, gosh, you think it could have been placed in a MORE inconvenient place? Hw often should they be changed?
How concerned should I be with the fuel pump, there being THAT much varnish in the tank- will that have gummed up the pump? |
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Thought it might be the filter, but, gosh, you think it could have been placed in a MORE inconvenient place? Hw often should they be changed? How concerned should I be with the fuel pump, there being THAT much varnish in the tank- will that have gummed up the pump? If you look in the front trunk the carpet is cut in a small rectangle. behind that is a plate that the pump attaches to. You can work the pump out from under the tank thru that hole. The filter will come out too. It is not very easy, but it can be done. They moved the pump up front in 74 i believe, maybe 75. Something to do with fires, or fuel smell in the cockpit. Looks like you have a good car there. Check the pelican parts site, I think they have a long list in their tech articles on getting everything up to snuff. just the basics.... fuel, brakes, lubrication and electric. Sounds easy. (IMG:style_emoticons/default/blink.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
They moved the pump up front in 74 i believe, maybe 75. Something to do with fires, or fuel smell in the cockpit. In 75. To cure vapor lock issues. (Which I have experienced a grand total of ONCE in my 74 in the past two decades.) --DD FWIW, One of our members vapor locked on our run after the BBQ last month. It was 95F and we pulled over after ascending appx 1500' up the mountain. I knew it would fire if would could get some gas thru it so we pushed him around and he headed back down, allowing it to get some cold gas thru the overheated FP. |
Lo-Fi Version | Time is now: 27th June 2024 - 01:58 AM |
