Flipping tires over - opinions?, (Hoosier A6) |
mskala |
Sep 24 2014, 02:08 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
This is my first autocross season using the Hoosier A6. Basically, given my
street-friendly suspension settings, I get more 'roll' on outside edge of the tires and after 8 days I figured I should flip them over if for no other reason than to avoid early cording at the edge. So, I did that and just did the first autocross, and they at first seemed terribly slippery (although the morning was kinda cold) and even by the end of the day still not as good as before. My times were off compared to others. I was told by a 'seasoned' guy I know there that it will take time to get them scrubbed in going the other way. Is this to be expected? Now that I think about it, across the whole tire the wear was not even (it gets a bit wavy), so flipping them must also put less rubber down to the pavement initially. Thanks for opinions. |
mskala |
Sep 25 2014, 04:09 PM
Okay, good info all. I have 80 runs on these, but things still felt good
and the times were good 2 events ago just before the flip. I am going to bump up the pressure from 29 to ~34 and also bring one of those infrared temp guns (I know it's not accurate but just to compare across tread). Hopefully this will use the rubber in the center of the tire and keep the rollover a bit less. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:42 AM |
