MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Hi all...I'm referring to the inner nut on the suspension ear ,inner end of pivot shaft.
Can anyone tell me why this nut always seems to loosen? Every time I put a wrench on it I can tighten it by about 1 turn. It tightens up, then a week later it's loose again? Car is a 74 2.0 liter, I have Eric's bushings in the trailing arm. Thanks!! Mike |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
According to the factory manual:
Control arm bearing on control arm. Inside = 87 ft. lbs Outside = 108 ft. lbs Both Self-locking hex.nut Threads M 14x1.5 Grade 8 G |
draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
According to the factory manual: Control arm bearing on control arm. Inside = 87 ft. lbs Outside = 108 ft. lbs Both Self-locking hex.nut Threads M 14x1.5 Grade 8 G Steve, not challenging your input but can you explain how you can torque down one side with a different value than the other side? How would you "hold" the axle without holding the other side with a wrench? Thanks! |
Lo-Fi Version | Time is now: 24th June 2024 - 07:25 AM |
