Loose suspension nut... |
MikeM |
Sep 22 2014, 10:46 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I'm referring to the inner nut on the suspension ear ,inner end of pivot shaft.
Can anyone tell me why this nut always seems to loosen? Every time I put a wrench on it I can tighten it by about 1 turn. It tightens up, then a week later it's loose again? Car is a 74 2.0 liter, I have Eric's bushings in the trailing arm. Thanks!! Mike |
914_teener |
Sep 25 2014, 10:09 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Exactly right Bruce...I don't see any way to torque the inner nut with the engine installed. Mike I was just out in my garage trying to remember if there was room because I have done it. You can get an extension with a short socket on there with ease. It won't rotate but about 15 deg or so but you definitely can get a tool on there. I don't know why you are saying the above. Just trying to help you. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:01 PM |
