brooks944 |
Member ![]() ![]() Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States ![]() |
Bought a new to me 914 in April and had issues ever since. Current one is it is very hard to start, my mechanic is using starter fluid to get it going. Cold start valve is disconnected and no wiring to support it, won't stay running without keeping the gas peddle pushed some, etc. He recommends changing to carbs, and with the limited paperwork I got with the car, the mechanic that rebuilt the engine from 1.8 to 2.2L recommended the same. What do you guys recommend, parts for the FI are much more than dual carbs and then I'll have to pay for all the troubleshooting with the FI.
If you recommend carbs, where is the best place to buy and what would you recommend for the modified 2.2L? Thanks, I need the help! Rick |
brooks944 |
I found where the engine is pushed out to 2l, not 2.2 as I posted earlier. There are no records on a cam change, but there is a part listing for a 'PEC' 96mm. What is that?
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I found where the engine is pushed out to 2l, not 2.2 as I posted earlier. There are no records on a cam change, but there is a part listing for a 'PEC' 96mm. What is that? 96mm piston and cylinder set. That makes the engine 1911 cc unless the crankshaft was also changed. Original FI on the 1.8L is L-Jet. L-Jet is very sensitive to vacuum leaks. They must be completely eliminated for the system to work properly. Keep the FI and we'll help you get it working. Or find a mechanic who understands how that FI system functions. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:11 AM |
