Carbs?, FI shot, what does everyone recommend |
brooks944 |
Sep 26 2014, 10:21 AM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Bought a new to me 914 in April and had issues ever since. Current one is it is very hard to start, my mechanic is using starter fluid to get it going. Cold start valve is disconnected and no wiring to support it, won't stay running without keeping the gas peddle pushed some, etc. He recommends changing to carbs, and with the limited paperwork I got with the car, the mechanic that rebuilt the engine from 1.8 to 2.2L recommended the same. What do you guys recommend, parts for the FI are much more than dual carbs and then I'll have to pay for all the troubleshooting with the FI.
If you recommend carbs, where is the best place to buy and what would you recommend for the modified 2.2L? Thanks, I need the help! Rick |
struckn |
Sep 27 2014, 05:47 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
One point of clearification not mentioned is, to install a cam for carb you will have to change the Fuel Pump to a lower pressure and drop the engine to disassemble, and split the case,which could be very expensive. Some other things would be needed as well such as Throttle cable, Fuel lines, etc.
(IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 11:37 AM |
