do the repro front hood seals suck? |
siverson |
Oct 7 2014, 11:46 PM
Advanced Member Group: Benefactors Posts: 2,451 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
yuck...
Attached thumbnail(s) |
bandjoey |
Oct 8 2014, 04:15 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I tried a piece of his rear trunk seal and it's too tall. Very little clearance in there. By not gluing I take the seal out after a rain to dry the channel. It does seal good.
Mikey914 |
Oct 8 2014, 11:25 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I tried a piece of his rear trunk seal and it's too tall. Very little clearance in there. By not gluing I take the seal out after a rain to dry the channel. It does seal good. I do have the tall profile and the OEM, the tall will definitely close the gap, the OEM tends to crush down over time. |
DRPHIL914 |
Oct 9 2014, 06:58 AM
Dr. Phil Group: Members Posts: 5,805 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I tried a piece of his rear trunk seal and it's too tall. Very little clearance in there. By not gluing I take the seal out after a rain to dry the channel. It does seal good. I do have the tall profile and the OEM, the tall will definitely close the gap, the OEM tends to crush down over time. I'd like to try this . Mark , if you can cut it to the correct length for the front to go all the way around, i'd like to get that from you . it would be just like the one i got from you that is in there rear trunk. PM me if you have time. if it works good on the rear, why not the front? that way the channels can drain the rain, not trap it and still keep the trunk dry. I am just not sure which height is needed, the OEM or yours. Seems like there is not much of a difference and the taller would still work better. Phil |
Lo-Fi Version | Time is now: 24th September 2024 - 01:04 PM |
