Anyone know how to set float levels on dual 40 IDF weber carbs? |
LCOX |
Oct 10 2014, 05:58 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
've got a set of dual webers IDF 40 carbs.
Anyone know how to properly set the float level height on these things. I've got a set of vernier calipers. I'm sure you probably carefully bend one or both of the metal tabs on each float assembly. What is the proper closed figure and the fully open figure. Thanx all L. |
Mblizzard |
Oct 11 2014, 09:16 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
A little tip I got from someone. Use a 10 mm bolt to measure. Check the size with a caliper and then use the head of the bolt against the gasket to set the level. Very quick and easy to use and you can be sure of when the valve is closed.
Lo-Fi Version | Time is now: 18th June 2024 - 07:34 AM |
