LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
've got a set of dual webers IDF 40 carbs.
Anyone know how to properly set the float level height on these things. I've got a set of vernier calipers. I'm sure you probably carefully bend one or both of the metal tabs on each float assembly. What is the proper closed figure and the fully open figure. Thanx all L. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Diagram in post above is from here:
http://www.redlineweber.com/html/Tech/40-4...s_breakdown.htm Logs of good info on that site. Poke around in the higher level links. And there is some confusion about setting the float level with or without the gasket. I set mine without, then read it should have been with the gasket. It currently runs fine, and will do it right next time I pull the tops. |
Lo-Fi Version | Time is now: 18th June 2024 - 07:38 AM |
