Gas Tank Adventures, Tank out, stripping paint... |
boxsterfan |
Sep 6 2014, 06:40 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, I start the process of replacing my fuel pump today (which has been relocated up front by PO). So I got the tank out and it was starting to look pretty "rusty". So I figured I woul attempt to strip it down and repaint it. I have gotten most of the paint stripped off, but how am i going to get some/all of this surface rust off?
Any good radiator shops in San Ramon area I could drop it off to have someone finish it for me this week? Note: the inside of the tank looks very good....as if someone re-did the tank sometime ago. Attached thumbnail(s) |
boxsterfan |
Oct 12 2014, 12:53 PM
Bruce, thanks for the message. I'm going to try some Evapo-Rust (have about a 1/2 bottle left) on the inside of my tank next weekend. See how that works.
Does anyone know if that Evapo-Rust will damage the inside coating at all? If so, I may just try the vinegar instead (and hey, that's cheaper). |
mepstein |
Oct 12 2014, 01:05 PM
914-6 GT in waiting Group: Members Posts: 19,336 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bruce, thanks for the message. I'm going to try some Evapo-Rust (have about a 1/2 bottle left) on the inside of my tank next weekend. See how that works. Does anyone know if that Evapo-Rust will damage the inside coating at all? If so, I may just try the vinegar instead (and hey, that's cheaper). If its rusting, then there's probably no coating inside the tank. stock is just bare steel. That's why it's important to keep fresh gas in the tank or some mmo if your leaving it empty. |
bdstone914 |
Oct 12 2014, 01:11 PM
bdstone914 Group: Members Posts: 4,560 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Bruce, thanks for the message. I'm going to try some Evapo-Rust (have about a 1/2 bottle left) on the inside of my tank next weekend. See how that works. Does anyone know if that Evapo-Rust will damage the inside coating at all? If so, I may just try the vinegar instead (and hey, that's cheaper). If its rusting, then there's probably no coating inside the tank. stock is just bare steel. That's why it's important to keep fresh gas in the tank or some mmo if your leaving it empty. I have used vinegar but have more of a problem with flash rust if you can't get it dried quickly. Bruce |
Lo-Fi Version | Time is now: 29th June 2024 - 06:23 AM |
