> Piston oil squirters for a /4...anyone have them?
Mueller
post May 26 2003, 02:20 PM
914 Freak!
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
r_towle
post Oct 26 2014, 08:23 AM
Custom Member
Brining this back up to the front of the line for more details please.
Not sure , based upon the picture, where this groove gets cut.
Does anyone have a rod to show that this modification has been completed?
Rich
Mueller   Piston oil squirters for a /4...anyone have them?   May 26 2003, 02:20 PM
Scott   Mike, You may want to check with FAT Performance....   May 26 2003, 02:23 PM
Scott   Hey Mike, See Brad's post on his dyno room, a...   May 26 2003, 02:29 PM
Mueller   Hey Scott, i know of a few shops that'll ins...   May 26 2003, 02:36 PM
Bleyseng   That was Bernie Bergman's experience on his tu...   May 26 2003, 02:39 PM
Brad Roberts   Not worth it. B   May 26 2003, 02:41 PM
Brad Roberts   I'll *probably* persue a turbo kit. But I prom...   May 26 2003, 02:43 PM
Aaron Cox   i read in hot vw's, that the type 1 crowd has ...   May 26 2003, 03:02 PM
Bleyseng   Will it have the option of NOS? Geoff   May 26 2003, 03:02 PM
Mark Henry   Mike, if your rods are nice and tight on the shoul...   May 26 2003, 05:08 PM
MJHanna   It depends on what your doing with the motor. I ha...   May 27 2003, 06:59 AM
Bleyseng   This is the mods I have done, is this what you are...   May 31 2003, 10:32 PM
Brad Roberts   I dont think that is what he is talking about.. H...   Jun 1 2003, 01:03 AM
Mark Henry   With the 30mm pump he's planning on running th...   Jun 1 2003, 05:10 AM
Bleyseng   Yes I did! But this is the pic I was looking f...   Jun 1 2003, 09:06 AM
seanery   what pic?   Jun 1 2003, 09:08 AM
Bleyseng   the one I posted previously. What the hell is all ...   Jun 1 2003, 09:14 AM
r_towle   Brining this back up to the front of the line for ...   Oct 26 2014, 08:23 AM
McMark   I've never seen the rod notch in person and I...   Oct 26 2014, 11:58 AM
DBCooper   I've never seen the rod notch in person and I...   Oct 27 2014, 06:55 AM
McMark   I don't know why they wouldn't work. Pre...   Oct 27 2014, 10:10 AM
stugray   isnt there also a mod that drills a very small hol...   Oct 26 2014, 12:15 PM
McMark   Here's that mod. The real Porsche squirters ...   Oct 26 2014, 12:29 PM
McMark   Check valve opens around 20psi.   Oct 26 2014, 12:31 PM
r_towle   Check valve opens around 20psi. Umm, not always ...   Oct 26 2014, 06:23 PM
Mark Henry   I've cut notches in rods, I'd say it likel...   Oct 26 2014, 06:42 PM
McMark   911 squirters are often replaced as a peace-of-min...   Oct 26 2014, 07:04 PM
wndsnd   911 squirters are often replaced as a peace-of-mi...   Oct 26 2014, 07:21 PM
Mark Henry   [quote name='McMark' post='2102942' date='Oct 26 ...   Oct 27 2014, 04:04 AM
JimN73   Somebody, Nate (aircoledtechguy), posted a photo o...   Oct 26 2014, 07:08 PM
Dave_Darling   "Better", of course! But is the not...   Oct 27 2014, 10:28 AM
DBCooper   Yeah, it would be great to know VW's engineeri...   Oct 27 2014, 01:27 PM
rudedude   They might be great until your 6 cylinder isn...   Oct 27 2014, 01:56 PM
r_towle   Seems doing this modification to the big end might...   Oct 27 2014, 02:57 PM
r_towle   Interesting Carrillo Rods do this modification als...   Oct 27 2014, 03:01 PM
McMark   Took a look at a spare case today. Looks like a pr...   Oct 27 2014, 10:54 PM
r_towle   From what I read, it is not straight... A slight ...   Oct 28 2014, 06:12 AM
Racer Chris   Notching the rods is simple and effective.   Oct 28 2014, 07:05 AM
aircooledtechguy   Notching the rods is simple and effective. :ag...   Oct 28 2014, 10:30 AM
McMark   directing a portion of that splash where you want...   Oct 28 2014, 06:44 PM
r_towle   One of the things I saw, which I can't seem to...   Oct 28 2014, 06:05 PM
aircooledtechguy   One of the things I saw, which I can't seem t...   Oct 28 2014, 06:37 PM
jcd914   I saw a you tube video where someone was machining...   Oct 28 2014, 06:31 PM
r_towle   Interesting to look at the Carrillo rods. They hav...   Oct 28 2014, 06:34 PM
Katmanken   Interesting to look at the Carrillo rods. They ha...   Oct 28 2014, 08:43 PM
r_towle   Carrillo cuts them offset also....figure they migh...   Oct 28 2014, 06:38 PM
Mark Henry   Really that's all that matters...   Oct 28 2014, 08:24 PM
McMark   Really that's all that matters... True, but ...   Oct 28 2014, 10:15 PM
Mark Henry   Really that's all that matters... True, but...   Oct 29 2014, 04:54 AM
falcor75   If you want threaded squirters you can grab them f...   Oct 29 2014, 05:09 AM
- Lo-Fi Version Time is now: 12th January 2025 - 08:02 PM
