> Piston oil squirters for a /4...anyone have them?
Mueller
post May 26 2003, 02:20 PM
914 Freak!
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
r_towle
post Oct 28 2014, 06:05 PM
Custom Member
One of the things I saw, which I can't seem to find again, showed a notch on both sides, offset to spray in different directions.
So instead of the notch being at 6 o'clock, it was at 7 on one side and 5 on the other side....so it would spray both ways.
aircooledtechguy
post Oct 28 2014, 06:37 PM
The Aircooledtech Guy
QUOTE(r_towle @ Oct 28 2014, 05:05 PM) *
Doing what you describe would have ZERO effect since the rods are always in motion in relation to the piston. This motion ensures that the spray is constantly moving across the piston crown on both sides. That would only be a factor if the rod stayed in a static position in relation to the piston.
Mueller   Piston oil squirters for a /4...anyone have them?   May 26 2003, 02:20 PM
Scott   Mike, You may want to check with FAT Performance....   May 26 2003, 02:23 PM
Scott   Hey Mike, See Brad's post on his dyno room, a...   May 26 2003, 02:29 PM
Mueller   Hey Scott, i know of a few shops that'll ins...   May 26 2003, 02:36 PM
Bleyseng   That was Bernie Bergman's experience on his tu...   May 26 2003, 02:39 PM
Brad Roberts   Not worth it. B   May 26 2003, 02:41 PM
Brad Roberts   I'll *probably* persue a turbo kit. But I prom...   May 26 2003, 02:43 PM
Aaron Cox   i read in hot vw's, that the type 1 crowd has ...   May 26 2003, 03:02 PM
Bleyseng   Will it have the option of NOS? Geoff   May 26 2003, 03:02 PM
Mark Henry   Mike, if your rods are nice and tight on the shoul...   May 26 2003, 05:08 PM
MJHanna   It depends on what your doing with the motor. I ha...   May 27 2003, 06:59 AM
Bleyseng   This is the mods I have done, is this what you are...   May 31 2003, 10:32 PM
Brad Roberts   I dont think that is what he is talking about.. H...   Jun 1 2003, 01:03 AM
Mark Henry   With the 30mm pump he's planning on running th...   Jun 1 2003, 05:10 AM
Bleyseng   Yes I did! But this is the pic I was looking f...   Jun 1 2003, 09:06 AM
seanery   what pic?   Jun 1 2003, 09:08 AM
Bleyseng   the one I posted previously. What the hell is all ...   Jun 1 2003, 09:14 AM
r_towle   Brining this back up to the front of the line for ...   Oct 26 2014, 08:23 AM
McMark   I've never seen the rod notch in person and I...   Oct 26 2014, 11:58 AM
DBCooper   I've never seen the rod notch in person and I...   Oct 27 2014, 06:55 AM
McMark   I don't know why they wouldn't work. Pre...   Oct 27 2014, 10:10 AM
stugray   isnt there also a mod that drills a very small hol...   Oct 26 2014, 12:15 PM
McMark   Here's that mod. The real Porsche squirters ...   Oct 26 2014, 12:29 PM
McMark   Check valve opens around 20psi.   Oct 26 2014, 12:31 PM
r_towle   Check valve opens around 20psi. Umm, not always ...   Oct 26 2014, 06:23 PM
Mark Henry   I've cut notches in rods, I'd say it likel...   Oct 26 2014, 06:42 PM
McMark   911 squirters are often replaced as a peace-of-min...   Oct 26 2014, 07:04 PM
wndsnd   911 squirters are often replaced as a peace-of-mi...   Oct 26 2014, 07:21 PM
Mark Henry   [quote name='McMark' post='2102942' date='Oct 26 ...   Oct 27 2014, 04:04 AM
JimN73   Somebody, Nate (aircoledtechguy), posted a photo o...   Oct 26 2014, 07:08 PM
Dave_Darling   "Better", of course! But is the not...   Oct 27 2014, 10:28 AM
DBCooper   Yeah, it would be great to know VW's engineeri...   Oct 27 2014, 01:27 PM
rudedude   They might be great until your 6 cylinder isn...   Oct 27 2014, 01:56 PM
r_towle   Seems doing this modification to the big end might...   Oct 27 2014, 02:57 PM
r_towle   Interesting Carrillo Rods do this modification als...   Oct 27 2014, 03:01 PM
McMark   Took a look at a spare case today. Looks like a pr...   Oct 27 2014, 10:54 PM
r_towle   From what I read, it is not straight... A slight ...   Oct 28 2014, 06:12 AM
Racer Chris   Notching the rods is simple and effective.   Oct 28 2014, 07:05 AM
aircooledtechguy   Notching the rods is simple and effective. :ag...   Oct 28 2014, 10:30 AM
McMark   directing a portion of that splash where you want...   Oct 28 2014, 06:44 PM
r_towle   One of the things I saw, which I can't seem to...   Oct 28 2014, 06:05 PM
aircooledtechguy   One of the things I saw, which I can't seem t...   Oct 28 2014, 06:37 PM
jcd914   I saw a you tube video where someone was machining...   Oct 28 2014, 06:31 PM
r_towle   Interesting to look at the Carrillo rods. They hav...   Oct 28 2014, 06:34 PM
Katmanken   Interesting to look at the Carrillo rods. They ha...   Oct 28 2014, 08:43 PM
r_towle   Carrillo cuts them offset also....figure they migh...   Oct 28 2014, 06:38 PM
Mark Henry   Really that's all that matters...   Oct 28 2014, 08:24 PM
McMark   Really that's all that matters... True, but ...   Oct 28 2014, 10:15 PM
Mark Henry   Really that's all that matters... True, but...   Oct 29 2014, 04:54 AM
falcor75   If you want threaded squirters you can grab them f...   Oct 29 2014, 05:09 AM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th January 2025 - 08:17 PM
