Stripped Gas Tank Threads |
cary |
Sep 12 2014, 09:36 PM
Working on replumbing my new fuel pump. So I decided to loosen the nuts that cinch down the fuel tank output pipes. Big one came off without a hitch. The return line, that's another story. The aluminum nut totally stripped out. Steel bung threads are embedded with aluminum.
Has anyone bought the M18 * 1.0 die or thread restorer and cleaned those threads before? Kind of an odd sized thread. Hate to give up on this tank. |
cary |
Oct 31 2014, 01:14 PM
Had I little trouble at hose shop. They don't really deal in the small stuff. But we finally found what I was looking for.
With my bunged up threads they were tough to get started and not go on cross threaded. But you can see them sitting here with 2 gallons of gas checking for leaks. Dry as a bone. But I am going to mark the bottom of the tank .... never remove bad threads I tested one of them on one of my other tanks. They went on smooth as silk. Nice product. Note : They seal with an O-ring. I'd say for cleaning the threads if the tank sealer is your only issue. Clean threads with the nut with the cuts in it. Oil as you go thru the cuts. I turn a 1/4, back up a 1/2. Rinse and repeat until you get to the bottom. I took it off once and cleaned the threads with a wire brush. Then use a new unused nut to tidy up the starter threads. |
Kansas 914 |
Oct 31 2014, 02:05 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Had I little trouble at hose shop. They don't really deal in the small stuff. But we finally found what I was looking for. With my bunged up threads they were tough to get started and not go on cross threaded. But you can see them sitting here with 2 gallons of gas checking for leaks. Dry as a bone. But I am going to mark the bottom of the tank .... never remove bad threads I tested one of them on one of my other tanks. They went on smooth as silk. Nice product. Note : They seal with an O-ring. I'd say for cleaning the threads if the tank sealer is your only issue. Clean threads with the nut with the cuts in it. Oil as you go thru the cuts. I turn a 1/4, back up a 1/2. Rinse and repeat until you get to the bottom. I took it off once and cleaned the threads with a wire brush. Then use a new unused nut to tidy up the starter threads. Looks like a job well done - thanks for documenting this repair so well - cheers! |
Lo-Fi Version | Time is now: 26th June 2024 - 09:13 AM |
