Transaxle trouble |
Transaxle trouble |
Hank914 |
Nov 3 2014, 12:17 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I earlier added to the "what you did today thread" but I thought I would start a new thread with some more details on my transaxle troubles.
So I recently installed by rebuilt tranny after the PNW tranny clinic. I also converted from tail to side shift, and all the bushings. The previous owner (40 yrs) rebuilt the engine after 97k miles in 2007, but afaik did nothing on the tranny. The bushings were shot. Last weekend, after logging 120 test miles around Central Oregon, I thought I'd take her down to the Bay Area. About 130 miles into the trip, I hear a loud bang and spin a 360 into the ditch. During the fun, I figured I had a blowout. But not tire problems just a locked up rear differential. I pulled the tranny and this is what I saw. (Please excuse the large photos, but it adds detail) So I opened up the tranny case and found some interesting stuff. Pictures to follow... |
jkb944t |
Nov 5 2014, 12:05 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I don’t see any gulling of the remaining section of the pinion so it wasn’t a setup issue.
It was either an inherent defect in the gear that was there from manufacturing that unfortunately decided to give out now or something foreign was floating inside the transmission and locked up in between the pinion gear teeth. Jeff B |
Hank914 |
Nov 5 2014, 01:12 PM
I don’t see any gulling of the remaining section of the pinion so it wasn’t a setup issue. It was either an inherent defect in the gear that was there from manufacturing that unfortunately decided to give out now or something foreign was floating inside the transmission and locked up in between the pinion gear teeth. Jeff B I looked pretty closely to see if there was any foreign floater object that I could identify as the reason. I found nothing but smaller bits of metallic shrapnel and the one larger "tooth" that broke off. Hence I think it is an inherent defect from the beginning. And that's why I started this tread. How often? Sounds like 'not very' is the consensus answer. |
Lo-Fi Version | Time is now: 17th January 2025 - 12:07 AM |
