michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
Hi everybody,
Long time since i posted something. After i converted my tenner to a six i was never happy with the Performance of the carbs. I had the Zenith rebuild by a professional, but they never worked as i expected. Over the time i got the idea to use a Injection System instead of the carbs. There are some sellers that provide ITB for Porsches like TWM or PMO. These were way to expensive for my Budget, so i did some Research and found Motorcycle ITB that fitted nearly perfect to the Motor. So i bought one set at about 70,- Euro to do the Engineering for the Adapter. The first pics Show the milling process, last one the finished part. ![]() ![]() ![]() ![]() |
michelko |
Next step was to fit the controler board into a motronic housing.
The controler is a megasquirt2 Derivate provided by no-limits Motorsport. ![]() ![]() ![]() With These Setup i was able to start the engine with just using the electronic ignition and the old carbs. The idea was not to Change to many variables at one time. Sorting out Errors is much easyer this way. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:32 AM |
