Won't start, need help from the gurus |
drewvw |
Nov 9 2014, 02:58 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
Hey All!
I used to be a frequent contributor here, but then kids and some other life stuff happened. Held onto the 914 though, and over the past year dropped the engine and did a much needed clutch/transmission service. Long story short, I can't get car to start again and after a lot of methodical investigating, would really appreciate some input. Here are some data points: - 1973 1.7 stock with DJET that always functioned great until engine came out. - Have discovered a bit of Frankenstein wiring. Fuel pump wired to coil/key on. - Went thru entire ignition after inconsistent spark. New (needed) wires, plugs, cap/rotor/points. Strong spark now. - Spray starting fluid in cylinders and it at least "pops". Original fuel injectors. When cranking I get ~.9 mV to each one at electrical plug. Have confirmed fuel to rails. - older merged exhaust with muffler part and air cleaner off. Not sure if that's enough to stop it from starting or not? In summary, I now feel good about spark but what am I missing on the fuel side? I suspect the injectors but I drove it to where it currently is. Any help would really be appreciated. Trying to get the old girl back in good form! Drew (IMG:style_emoticons/default/beer.gif) |
Cap'n Krusty |
Nov 9 2014, 04:01 PM
Are you sure the 2 fuel lines are connected properly? Pressure regulator outlet hose, across engine to return ("Y") fitting at pump, right side rail to pressure ("D" on pump)?
The Cap'n |
Lo-Fi Version | Time is now: 26th September 2024 - 11:41 AM |
