Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
I recentely have the red car running again. went back to stock 2056cc with heat exchangers and 44 webers.
Question now is oil temp. I think i installed the wrong sender for the VDO. The gauge reads 250 degrees at hot. What is the normal running temp on our cars and how can I check the temp without removing the taco plate?. I tired a priometer and it read 160 degrees at the dipstict at 250+ at the guage. I am running Brad Penn start up oil, and do not want to drain until break in is done....... |
Jesco Reient |
Member ![]() ![]() Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest ![]() |
I recentely have the red car running again. went back to stock 2056cc with heat exchangers and 44 webers. Question now is oil temp. I think i installed the wrong sender for the VDO. The gauge reads 250 degrees at hot. What is the normal running temp on our cars and how can I check the temp without removing the taco plate?. I tired a priometer and it read 160 degrees at the dipstict at 250+ at the guage. I am running Brad Penn start up oil, and do not want to drain until break in is done....... So the car is running cooler and happier now. Dave is smiling along the road! |
Lo-Fi Version | Time is now: 25th June 2024 - 12:59 AM |
