bluhun |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California ![]() |
I purchased a set of the Hayward and Scott heat exchangers for my 1975 3.2 liter conversion several months ago. The conversion was performed 5 years ago and designed around the Billy Boat heat exchangers and muffler system. I was not happy with the B&B system because of the inadequate flow of hot air it delivered, and decided to give the H&S system a try. Attached is a picture of the H&S heat exchangers.
Unfortunately, and not surprisingly, we encountered significant fitment issues with the H&S heat exchangers. First of all, the exhaust primaries would not bolt up with the cylinder heads without enlarging the bolt holes on the exhaust flanges. Not a big issue, just enlarge the holes. The hot-air exit tube on the exchangers needs to be extended by several inches to bolt up to the heater-control valves. The collector end of the exhaust would not mate up with the B&B muffler, necessitating the purchase of a standard 911 banana-type muffler. The most significant fitment issue, however, is that the system interferes with oil changes and exhaust-valve adjustments, requiring the exhaust to be removed in order to do an oil change or an engine service. We reluctantly decided to retain the B&B system for the car, and new heater-control valves did significantly improve the hot-air flow. All-in-all, this has been a very expensive lesson. The H&S exchangers come with 1-3/4" primaries and a 2" collector. The driver's-side comes with an O2-sensor bung installed. I am willing to sell them for considerably less than I paid for them ($2,900 including shipping). I will be posting an ad in the classified section. Attached thumbnail(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
A combined effort between a good tubing shop and someone like restoration design for stamping may make it a worthwhile thing to do....
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,104 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
A combined effort between a good tubing shop and someone like restoration design for stamping may make it a worthwhile thing to do.... I'm in, but I don't have the facilities/skill to do it. I've been thinking about this for quite some time. Yea, stainless is nice, but mild steel and then get it coated would make it much easier to produce. The sheet metal heat exchangers (and the thru holes for the exhaust nuts) would be a little bit of work, but once you got the pattern done. Just look on the VIN registry-there are a lot of 'real' sixes still out there, plus a bunch of conversions. They can't all be in SoCal where you don't want/need heat so you can run headers. By the way, if anyone knows how to adjust the exhaust valves on a six WITHOUT removing the heat exchangers, or dropping the engine/trans slightly, I'm all ears. I've never been able to figure out how to get the valve covers off, let alone adjust the valves with removing them. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:31 PM |
