Bushings for shift rod coupling, How to install |
jack20 |
Nov 21 2014, 09:14 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Ordered all new shift linkage bushings. The bushings for the coupling near firewall have me stumped. Does the rod need to be pressed out to install the bushings? Or...do I remove the old bushing and slip the new ones in from the outside?
AvalonFal |
Nov 21 2014, 10:15 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Use a piece of pipe or tubing that will fit over the pin and set it in a vise. Using a drift sized slightly smaller than the pin, press the pin through. Be VERY sure that the vise jaws are on the pipe tubing AND the drift (I used a bolt slightly smaller than the pin) and NOT on the coupler itself. The vise jaws press the bolt into the pin, pushing it out through the hole in the pipe tube. I reversed the process with a few modifications to press in the pin with the new bushing. Here's a pic of my removal setup:
Lo-Fi Version | Time is now: 25th June 2024 - 08:31 PM |
