drewvw |
new england car guy ![]() ![]() ![]() Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States ![]() |
Hey All!
I used to be a frequent contributor here, but then kids and some other life stuff happened. Held onto the 914 though, and over the past year dropped the engine and did a much needed clutch/transmission service. Long story short, I can't get car to start again and after a lot of methodical investigating, would really appreciate some input. Here are some data points: - 1973 1.7 stock with DJET that always functioned great until engine came out. - Have discovered a bit of Frankenstein wiring. Fuel pump wired to coil/key on. - Went thru entire ignition after inconsistent spark. New (needed) wires, plugs, cap/rotor/points. Strong spark now. - Spray starting fluid in cylinders and it at least "pops". Original fuel injectors. When cranking I get ~.9 mV to each one at electrical plug. Have confirmed fuel to rails. - older merged exhaust with muffler part and air cleaner off. Not sure if that's enough to stop it from starting or not? In summary, I now feel good about spark but what am I missing on the fuel side? I suspect the injectors but I drove it to where it currently is. Any help would really be appreciated. Trying to get the old girl back in good form! Drew (IMG:style_emoticons/default/beer.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Double check all wire and hose connections. If, for instance, the CHT is unplugged the car will really not want to start.
On the fuel pump, "S" comes from the fuel filter (which comes from the fuel tank), "D" goes to the right-side fuel rail, and "R" goes to the Y fitting that goes to the fuel tank and also to the fuel pressure regulator. --DD |
Lo-Fi Version | Time is now: 25th June 2024 - 12:07 AM |
