> Any successful radiator in engine compartment conversions?, Or other than front trunk installs?
Mueller
post Dec 5 2014, 01:05 PM
914 Freak!
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
effutuo101
post Dec 5 2014, 09:34 PM
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans?
Inquiring minds want to know.
Mueller
post Dec 5 2014, 09:49 PM
914 Freak!
QUOTE(effutuo101 @ Dec 5 2014, 07:34 PM) *
Exactly, water is a more efficient medium than air so if that compartment can shed 300hp worth of an air cooled* 3.6 it seems that same space can shed the heat from a 300hp 4 or 6 water cooled motor
*anyone have the numbers how much cooling is really done by the oil?
post Dec 6 2014, 11:36 PM
Resident German
QUOTE(Mueller @ Dec 5 2014, 07:49 PM) *
Exactly ...
No, not exactly ...
On the air cooled engines, there is a clear separation between the intake side of the engine and the underside where the hot air is expelled.
Without that separation, our aircooled engines would be very short-lived.
I have yet to see any watercooled solution that followed the same principal.
904svo
post Dec 7 2014, 09:57 PM
904SVO
QUOTE(SirAndy @ Dec 6 2014, 09:36 PM) *
Exactly ...
No, not exactly ...
Here is my rear mounted radiator in my 904 kit car (engine is a Subaru WRX)
I'm using a stock Subatu radiator and fans, the engine runs at 195 degrees. I'm
using the air coming off the rear deck to supply cool air into the radiator and
having the air exhaust under the car (low pressure area when moving)
Here are the pictures
post Dec 7 2014, 10:04 PM
Resident German
QUOTE(904svo @ Dec 7 2014, 07:57 PM) *
And that would fit in a 914 how exactly?
904svo
post Dec 7 2014, 10:16 PM
904SVO
QUOTE(SirAndy @ Dec 7 2014, 08:04 PM) *
Just to prove a point. As long as you can get the air flowing thru the radiator and exhaust it (air flow) you can mount the radiator or radiators any were.
Mueller   Any successful radiator in engine compartment conversions?   Dec 5 2014, 01:05 PM
76-914   Robert (rotary914) has. However, there is lots of ...   Dec 5 2014, 02:40 PM
shoguneagle   Master Mueller's "engineering mind" ...   Dec 5 2014, 02:57 PM
Mueller   Master Mueller's "engineering mind...   Dec 5 2014, 03:03 PM
effutuo101   My 2.5 suby turbo goes up to get the final bracket...   Dec 5 2014, 03:21 PM
d914   jeep cherokee rad is like 10 x 36 and they make al...   Dec 5 2014, 04:42 PM
GeorgeRud   I always thought that using two small radiators in...   Dec 5 2014, 04:54 PM
mepstein   I would love for the radiator to work in the engin...   Dec 5 2014, 07:45 PM
bulitt   I would love for the radiator to work in the engi...   Dec 9 2014, 02:28 AM
mepstein   I would love for the radiator to work in the eng...   Dec 9 2014, 05:32 AM
Chris914n6   ^^ Countach and Diablo. GT engine lid and some sc...   Dec 5 2014, 08:00 PM
DBCooper   Uh huh, that's the theory....   Dec 5 2014, 09:29 PM
effutuo101   So, running an air cooled big 6 gets enough air. W...   Dec 5 2014, 09:34 PM
Mueller   So, running an air cooled big 6 gets enough air. ...   Dec 5 2014, 09:49 PM
SirAndy   So, running an air cooled big 6 gets enough air. W...   Dec 6 2014, 11:36 PM
904svo   [quote name='Mueller' post='2118709' date='Dec 5 ...   Dec 7 2014, 09:57 PM
SirAndy   Here is my rear mounted radiator in my 904 kit car...   Dec 7 2014, 10:04 PM
904svo   Here is my rear mounted radiator in my 904 kit ca...   Dec 7 2014, 10:16 PM
Brian Mifsud   [quote name='Mueller' post='2118709' date='Dec 5 ...   Jun 26 2015, 12:23 PM
Mueller   Adding to this.. the 911 engine uses Mechanical...   Jun 26 2015, 04:37 PM
Brian Mifsud   hmmm, maybe we are looking at this the wrong wa...   Jun 29 2015, 10:49 AM
SirAndy   Years ago, at an autocross, I had to laugh at the...   Jun 29 2015, 09:14 PM
Brian Mifsud   Years ago, at an autocross, I had to laugh at th...   Jun 30 2015, 10:42 AM
Dave_Darling   ...taking furnace ducting, and running it straight...   Jun 30 2015, 09:02 AM
SirAndy   water is a more efficient medium than air so And ...   Dec 6 2014, 11:41 PM
worn   water is a more efficient medium than air so And...   Jun 26 2015, 07:11 PM
Dave_Darling   It's also been done with an N/A Scooby motor. ...   Dec 5 2014, 09:41 PM
thelogo   I always though a rear spoiler with a radiator en...   Dec 5 2014, 10:39 PM
r_towle   Mike, don't do it. Keep it aircooled and drive...   Dec 5 2014, 10:46 PM
veekry9   https://www.google.ca/search?q=f1+chassis&a...f-e%...   Dec 6 2014, 02:35 AM
veekry9   The fan is a centrifugal pump, just like any cent...   Dec 6 2014, 03:10 AM
mgp4591   Interesting side rad setup... would you have that ...   Dec 6 2014, 03:16 AM
veekry9   Step to the left. Step to the right.   Dec 6 2014, 04:33 AM
veekry9   Not the first.   Dec 6 2014, 07:24 AM
mepstein   it's easy to cool when the car is moving. It...   Dec 6 2014, 07:46 AM
DBCooper   Yup, lots of theory to go around, but to answer th...   Dec 6 2014, 07:47 AM
veekry9   http://www.performanceforums.com/forums/sh...he-po...   Dec 6 2014, 08:25 AM
76-914   I love to watch this subject resurface. A lot of a...   Dec 6 2014, 10:04 AM
veekry9   "RSK must be Peter Harburg's, because the...   Dec 6 2014, 11:48 AM
messix   the advantage of front mount is that once the car ...   Dec 6 2014, 12:35 PM
veekry9   If you planning to race it exclusively,a rad mount...   Dec 6 2014, 11:24 PM
thelogo   Where do water cooled 911 s mount the radiator C...   Dec 7 2014, 07:07 PM
Chris914n6   ^^ most newer mid engine cars do the corner rads a...   Dec 7 2014, 08:27 PM
veekry9   http://www.fiero.nl/forum/Forum3/HTML/000116-29.ht...   Dec 7 2014, 09:03 PM
mgp4591   There's alot of room for the radiator out in b...   Dec 7 2014, 10:13 PM
JRust   My NA 2.5 subaru leaves a bunch of room in the tru...   Dec 7 2014, 10:19 PM
Andyrew   I think it has all to do with the size of the moto...   Dec 8 2014, 09:22 AM
thelogo   How about Targa top mount As crazy as it sounds ...   Dec 8 2014, 11:32 AM
veekry9   There's alot of room for the radiator out in ...   Dec 8 2014, 12:27 PM
Chris914n6   I crunched some numbers. Based on a few sedans I ...   Dec 8 2014, 12:33 PM
fiid   It seems doable to do radiators in the engine bay,...   Dec 8 2014, 12:34 PM
McMark   Maybe a centrifugal fan on the crank wheel that bl...   Dec 8 2014, 12:53 PM
SirAndy   Logically, if a 3.6 can work, you should be able t...   Dec 8 2014, 01:38 PM
sixnotfour   :D   Dec 8 2014, 02:12 PM
DBCooper   The question was whether a radiator had been succe...   Dec 8 2014, 03:21 PM
76-914   Paul makes a good point re: heat sink. I watched i...   Dec 8 2014, 08:13 PM
Andyrew   You know what would be an interesting fail safe, I...   Dec 8 2014, 10:50 PM
RobW   You could mount an oil cooler right behind the 914...   Dec 9 2014, 12:03 AM
veekry9   You know what would be an interesting fail safe, ...   Dec 9 2014, 01:06 AM
timothy_nd28   Laying a radiator flat in the front trunk?   Jan 19 2015, 01:28 AM
Mueller   Laying a radiator flat in the front trunk? Go...   Jan 19 2015, 04:45 PM
Mike Bellis   I had a radiator built to lay flat in the front tr...   Jan 19 2015, 09:27 AM
Andyrew   I had a radiator built to lay flat in the front t...   Jan 19 2015, 09:57 AM
rdauenhauer   Scott Thacher was the guy who showed up in WCR 05 ...   Jan 19 2015, 09:44 AM
rick 918-S   Scott Thacher was the guy who showed up in WCR 05...   Jun 26 2015, 03:25 PM
Andyrew   [quote name='rdauenhauer' post='2135972' date='Ja...   Jun 26 2015, 06:25 PM
DBCooper   Cool, this thread came back. In the meantime I ra...   Jan 19 2015, 10:05 AM
DBCooper   Unfortunately a lot of rear-mount cooling projects...   Jan 19 2015, 10:58 AM
3d914   OK, here's mine. Not done, but in process. I h...   Jan 19 2015, 01:59 PM
Mueller   Crazy idea time..... Still have "something...   Jan 19 2015, 04:57 PM
DBCooper   I've seen finned aluminum tubing a bit like th...   Jan 19 2015, 06:56 PM
Dave_Darling   Talk to Chuck at Elephant Racing in SJ. They do m...   Jan 19 2015, 07:10 PM
timothy_nd28   Trane has been using this for decades, highly high...   Jan 19 2015, 07:55 PM
Mueller   Trane has been using this for decades, highly hig...   Jan 19 2015, 08:03 PM
Mueller   New Lamborghini Huracan has rear mounted radiators...   Jun 26 2015, 10:45 AM
Chris H.   Yes, always pull air, never push (Mike Bellis). ...   Jun 26 2015, 05:22 PM
914forme   Motorcycle Rads I have thought about several times...   Jun 26 2015, 07:50 PM
Chris914n6   Looking at racing rads for toyota celica/mr2/spyde...   Jun 29 2015, 02:39 PM
Andyrew   You talking about these puppies? http://www.ebay....   Jun 29 2015, 08:51 PM
Chris H.   You talking about these puppies? http://www.ebay...   Jun 29 2015, 11:40 PM
Chris914n6   You talking about these puppies? http://www.ebay...   Jun 30 2015, 02:15 PM
Bill D   For the TD I was able to fit the radiator next to ...   Jun 30 2015, 06:36 PM
Mike Bellis   For the TD I was able to fit the radiator next to...   Jun 30 2015, 07:24 PM
Bill D   My project is no where near as ambitious as your...   Jul 1 2015, 05:57 AM
Andyrew   Impressive that you were able to make that work...   Jun 30 2015, 09:42 PM
matthepcat   I like it. As I understand it the diesel runs coo...   Jul 1 2015, 09:43 AM
Bill D   I like it. As I understand it the diesel runs co...   Jul 1 2015, 12:01 PM
flmont   Iam considering a 4.3 ltr chevy v6 system,.with a...   Jul 7 2015, 07:13 PM
Mueller   Not a 914, but I think close enough, went to small...   Feb 5 2017, 04:13 PM
Mueller   I think what might help for any of these type swap...   Feb 5 2017, 04:16 PM
mepstein   Why don't you do it and report back. You don...   Feb 5 2017, 06:27 PM
sotaro   Why don't you do it and report back. You don...   Feb 27 2017, 09:21 PM
Rand   Aren't there examples of mid-engined sports/su...   Feb 27 2017, 10:03 PM
mepstein   Are the radiators in boxters in the front?   Feb 28 2017, 06:27 AM
Andyrew   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 07:05 AM
mepstein   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 07:49 AM
Andyrew   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 09:17 AM
914forme   Positive pressure is king to cooling. And there i...   Feb 28 2017, 09:03 AM
Mueller   Twin side mounted radiators, good enough for a big...   Feb 28 2017, 04:54 PM
mepstein   Twin side mounted radiators, good enough for a bi...   Feb 28 2017, 07:04 PM
69 User(s) are reading this topic (69 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd February 2025 - 11:03 AM
