> Hi/Lo Headlight Relay, 4prong vs 5 prong?
jPs
post Aug 26 2004, 06:17 PM
Hi All,
I picked up a 914 a week ago and am trying to iron out a few bugs before I get it back on the road and have reached a point where I sure could use a little advise. So here it is: The headlights won't switch between hi/low and in trying to figure this out I took the steering wheel off to check the turn/hi/low switch. It looked good and so after cleaning it all up I still didn't have much luck. So I then took the relay out (on the fuse panel) and noted it looked new. The PO I got this from had given me some extra parts and I noticed the old relay mixed in with them. The difference between the two is the new one is 5 prong, the old is 4 prong. I put the old one in and it would switch between hi/lo but not all the time.
So, I called the porsche dealership and the manager was very helpful and suggested I contact the guys over at the VW side of the dealership and have them order the new relay as it would be cheaper. I picked it up today and it was the same 5 prong I already had. In short, I went back to porsche and ordered what will hopefully be a 4 prong but the guy said the parts sheet didn't show if it was 4 or 5 but we'd find out. So I guess my question is will the 5 prong work and if so anyone know how? The schematics look close but I don't do electronics very well and basically am clueless. One thing I know for sure is if I can get the new 5 prong working I could save some cash for other items I need.
Any advise is appreciated. Thanks!
Tab914
post Aug 26 2004, 06:31 PM
You can also open up the four prong relay by just folding back the metal around the base of the relay. Look in there and see if a contact just needs to be resoldered. I did this whith mine when it stopped working and a wire had somehow broken from it's contact. Once resoldered I put the cover back on the relay, rebent the metal to hold it to the base and it has been working fine since. SAVE CASH TOO. Hope you can do the same. (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 11:30 PM
