> Is this part of the clutch?, I STILL NEED HELP
PanelBilly
post Dec 9 2014, 02:46 PM
Found this with the clutch parts. It looks like a bearing for the tranny, but I'm not sure. Is it part of the clutch assembly?
McMark
post Dec 10 2014, 06:29 PM
914 Freak!
Okay, install the pilot bearing in the flywheel. Recess it 3.2mm (or so). You have to leave room for the felt washer. Drop the felt washer into place, and the 'lock plate' goes over everything.
PanelBilly   Is this part of the clutch?   Dec 9 2014, 02:46 PM
McMark   pilot bearing   Dec 9 2014, 02:50 PM
PanelBilly   So where does the pilot bearing go?   Dec 9 2014, 04:41 PM
Mike Bellis   So where does the pilot bearing go? In the flywh...   Dec 9 2014, 04:42 PM
SirAndy   So where does the pilot bearing go? Inside the ce...   Dec 9 2014, 04:45 PM
roblav1   Most engines I've seen have the pilot bearing ...   Dec 9 2014, 07:44 PM
r_towle   It goes in the pilot bearing hole.....duh   Dec 9 2014, 07:45 PM
Cap'n Krusty   In the 914/4 it goes in the flywheel. The same en...   Dec 9 2014, 09:08 PM
McMark   He wouldn't be here if he had a bus. :P Ha...   Dec 10 2014, 02:06 AM
Cap'n Krusty   He wouldn't be here if he had a bus. :P Ha...   Dec 11 2014, 08:27 AM
Bleyseng   Make sure you have the spacer in the crank or the ...   Dec 10 2014, 08:27 AM
Cap'n Krusty   Make sure you have the spacer in the crank or the...   Dec 11 2014, 08:30 AM
PanelBilly   I think I'm Ben more confused now.   Dec 10 2014, 11:46 AM
PanelBilly   So does the bearing slide onto the tranny shaft? a...   Dec 10 2014, 12:08 PM
wndsnd   So does the bearing slide onto the tranny shaft? ...   Dec 10 2014, 12:17 PM
rjames   Both go in the flywheel. The felt washer towards ...   Dec 10 2014, 01:23 PM
McMark   Okay, install the pilot bearing in the flywheel. ...   Dec 10 2014, 06:29 PM
Steve Pratel   Thanks for this. I was tracking on the felt washer...   Dec 11 2014, 02:38 PM
sixnotfour   early 3.0 the bearing is in the flywheel, later 3....   Dec 10 2014, 06:56 PM
Jon H.   I always read that you when you replace the fly th...   Dec 11 2014, 05:49 AM
76-914   Oh it gets mentioned. Usually by the guy that forg...   Dec 11 2014, 08:28 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 03:36 PM
