> Is this part of the clutch?, I STILL NEED HELP
PanelBilly
post Dec 9 2014, 02:46 PM
Found this with the clutch parts. It looks like a bearing for the tranny, but I'm not sure. Is it part of the clutch assembly?
Jon H.
post Dec 11 2014, 05:49 AM
I always read that you when you replace the fly that the felt needs to be replaced but why does nobody ever mention the the o-ring thats in the flywheel- #6 in the diagram? I have replaced them before.
Jon H.
PanelBilly   Is this part of the clutch?   Dec 9 2014, 02:46 PM
McMark   pilot bearing   Dec 9 2014, 02:50 PM
PanelBilly   So where does the pilot bearing go?   Dec 9 2014, 04:41 PM
Mike Bellis   So where does the pilot bearing go? In the flywh...   Dec 9 2014, 04:42 PM
SirAndy   So where does the pilot bearing go? Inside the ce...   Dec 9 2014, 04:45 PM
roblav1   Most engines I've seen have the pilot bearing ...   Dec 9 2014, 07:44 PM
r_towle   It goes in the pilot bearing hole.....duh   Dec 9 2014, 07:45 PM
Cap'n Krusty   In the 914/4 it goes in the flywheel. The same en...   Dec 9 2014, 09:08 PM
McMark   He wouldn't be here if he had a bus. :P Ha...   Dec 10 2014, 02:06 AM
Cap'n Krusty   He wouldn't be here if he had a bus. :P Ha...   Dec 11 2014, 08:27 AM
Bleyseng   Make sure you have the spacer in the crank or the ...   Dec 10 2014, 08:27 AM
Cap'n Krusty   Make sure you have the spacer in the crank or the...   Dec 11 2014, 08:30 AM
PanelBilly   I think I'm Ben more confused now.   Dec 10 2014, 11:46 AM
PanelBilly   So does the bearing slide onto the tranny shaft? a...   Dec 10 2014, 12:08 PM
wndsnd   So does the bearing slide onto the tranny shaft? ...   Dec 10 2014, 12:17 PM
rjames   Both go in the flywheel. The felt washer towards ...   Dec 10 2014, 01:23 PM
McMark   Okay, install the pilot bearing in the flywheel. ...   Dec 10 2014, 06:29 PM
Steve Pratel   Thanks for this. I was tracking on the felt washer...   Dec 11 2014, 02:38 PM
sixnotfour   early 3.0 the bearing is in the flywheel, later 3....   Dec 10 2014, 06:56 PM
Jon H.   I always read that you when you replace the fly th...   Dec 11 2014, 05:49 AM
76-914   Oh it gets mentioned. Usually by the guy that forg...   Dec 11 2014, 08:28 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:30 PM
