Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We just finished the mold for the grills on the late air box and they look just like factory (less the over spray). The grills have been harder to find in good condition but now you can get one NEW!
No new grill would be complete without a new seal to hold it into place. We didn't just phone this one in. Other seals use an extruded strip of rubber and notch the corners to make a rectangle to hold the grill and slide over the top of the air box. We molded a seal to fit the air box perfectly. We also made it out of silicone to make a good seal. Not just a fin or flap, but a little over 1/4" flat seal all the way around. The real beauty of this seal is that when it is installed it will actually force the grill to sit about 1/16" below the body grill. These will be about $25 each for the seal and the same for the grill after the GB is over. It's also a good time to re seal the flapper valved in the air box, so if you want to add that in, it has been discounted to make this project more complete. Attached thumbnail(s) ![]() Attached image(s) ![]() |
Mikey914 |
Its the 2 flapper seals and the main motor and upper box seal.
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
